Posted May 1, 200421 yr comment_79183 i have a howl that seems to be getting worse. it seemed to start when i changed the springs. it used to only be slow speeds, and now it happens at any speed. i dont think it is the bearing but i am going to check it in the morning. any other ideas? tks Link to comment https://www.classiczcars.com/forums/topic/11518-howl/ Share on other sites More sharing options...
May 1, 200421 yr comment_79184 Be sure to check the U-joints carefully. By changing the springs, you have effectively changed the angle of the half shafts and that could be where all the noise is coming from. Link to comment https://www.classiczcars.com/forums/topic/11518-howl/#findComment-79184 Share on other sites More sharing options...
May 1, 200421 yr Author comment_79185 what would i be looking for? and if i found something i would get new ones? Link to comment https://www.classiczcars.com/forums/topic/11518-howl/#findComment-79185 Share on other sites More sharing options...
May 3, 200421 yr comment_79408 I also have been nursing a cyclic howl from the backend on my 1971 240Z. I believed it to be the differential but when I pulled it apart last week found a very rough noise from the rear wheel identified after disconnecting the axle shaft. Source was the outer bearing on the stub axle. Rough universals in the driveshaft or axle shafts may also generate a howl or clunk. Link to comment https://www.classiczcars.com/forums/topic/11518-howl/#findComment-79408 Share on other sites More sharing options...
