Posted March 22, 200223 yr comment_4383 can soeone explain me how they work? I have Eibach springs on my Z, but I have'nt driven it yet, so is there a visual way to tell the diference or it by the seat of the pants feeling? Link to comment https://www.classiczcars.com/forums/topic/1154-eibach-progressive-springs-explanation/ Share on other sites More sharing options...
March 29, 200223 yr comment_4728 heres what MSA emailed me when i was shopping:"We do have the European springs, they don't lower the car (so if you haveoriginal springs, your car is likely to go back up substantially) and theyare 11-18% stiffer than stock. The Eibachs lower the car about 1" from stockride height, and are progressive, where they will be not far from stockwhile cruising straight down the highway for comfort, but when you cornerthey can get up to 25% stiffer. If you are NOT going to race at all withthese springs, the Eibachs would be a good bet. If you do plan to race laterwith these springs, we would recommend the Tokico springs, which are up to25% stiffer than stock, and just the fronts are slightly progressive. Apartfrom stock, all will feel fairly stiffer, even the European ones. If goingback to original stock ride height is not a good option for you (plenty ofspace above the tires) than don't choose the Europeans. "If this leaves you with some more questions, let us know, you can alsorequest a current catalog at www.zcarparts.com/catalog.cfmMotorsport Auto1139 West Collins AveOrange, CA 92867Sales (800)633-6331Tech (714)639-2620www.zcarparts.comwww.miataparts.com Link to comment https://www.classiczcars.com/forums/topic/1154-eibach-progressive-springs-explanation/#findComment-4728 Share on other sites More sharing options...
March 29, 200223 yr Author comment_4744 Merci! Link to comment https://www.classiczcars.com/forums/topic/1154-eibach-progressive-springs-explanation/#findComment-4744 Share on other sites More sharing options...
March 29, 200223 yr comment_4752 The way to distinguish the progressive rate spring by looking at them is this. If you jack up the front end to take the weight off the suspension the coils will be spaced much further apart at the top of the spring than at the bottom. The more suspension travel you use (in cornering) the stiffer they will get. The stock or lowering springs of any type will have evenly spaced coils. Some progressive rate spring also may have slightly thicker diameter wire at the bottom, depending on how much progression the rate has. Link to comment https://www.classiczcars.com/forums/topic/1154-eibach-progressive-springs-explanation/#findComment-4752 Share on other sites More sharing options...
