Then you really wouldnt need one as it has a recirculating type bov from the factory.
Until you start adding more power and boost to the car I wouldnt worry about it yet.
The biggest bang for the buck is a 3 inch mandrel bent exhaust from the turbo back
Nets you 20 hp
I don't think it has a BOV from the factory but I think you can hold off on it until you swap out the J-pipe with a intercooler. Then you can plumb the BOV anywhere before the throttle body and tee off any vacuum line on the intake manifold. If you really wanted to, you could figure out a way to mount one on the J-pipe but you have to recirculate it back to the intake or your car will run rich between shifts and will stall.
