Hi,
i've been reading Haynes repair manual looking for the torque setting for the bolts on the camshaft holder(tunnel - i dont know the term) and i dont think its mentioned anywhere. Does anyone know how much torque i should put. i am using a 10 mm socket to it, so i am thinking it should not be more than 15lbs.
thanks,
hf
https://www.classiczcars.com/forums/topic/1162-torque/
Well, I looked through two factory manuals before I found it.
6 ft/lbs for the camshaft locating plate bolts. Since the only other bolts on the camshaft is the sprocket bolt I guess that these must be the cam tower mounting bolts (why they didn't call them that to make it easier?).
https://www.classiczcars.com/forums/topic/1162-torque/#findComment-4422
