Posted May 9, 200420 yr comment_80302 Hey guys, i just got a pioneer DEH-p6400 and i need some help installing it, because i clearly need to do some fitting. Plus, will it work in my car? thanks. Link to comment https://www.classiczcars.com/forums/topic/11635-installing-a-deck/ Share on other sites More sharing options...
May 9, 200420 yr comment_80310 search button!Early Z's are a PITA to install stereos in. Link to comment https://www.classiczcars.com/forums/topic/11635-installing-a-deck/#findComment-80310 Share on other sites More sharing options...
May 9, 200420 yr Author comment_80315 I did search, and im just wondering, whats the best way to make cuts into my console? and the adapters are differnent for the Z,I have the right plug but i'll need to cut and attach it to the Z plug, is this ok? any tips?!?! Link to comment https://www.classiczcars.com/forums/topic/11635-installing-a-deck/#findComment-80315 Share on other sites More sharing options...
May 9, 200420 yr comment_80325 the receiver ion my 290Z is connected to the factory plug, but I could only figure out the one wire to the RH speaker. It might be easier to just run speaker wires straight from the receiver, and I think you can get power off the factury plug.Don't bother with the radio unless you have everything else working first. Link to comment https://www.classiczcars.com/forums/topic/11635-installing-a-deck/#findComment-80325 Share on other sites More sharing options...
May 10, 200420 yr comment_80354 It will work in your car.Firstly, is the hole in the dash large enough to fit the CD player, or do you need to enlarge it to make it fit?I rewired mine when installing, because the original wires were designed to drive a low powered stereo, and your new one is a high powered CD player with a colour screen, and hence will struggle on the bass notes (turn it up and the screen will dimm with each beat) Run a new thicker wire from somewhere, with an inline fuse. And add a new ground wire, fixed to a clean ground area. Good idea to re-new the speaker wires as well.Get a mate who knows what he is doing to show you and spend the time doing it right. I skimped timewise on one thing on my last stereo install and now I have to fix it.Have fun.Scott Link to comment https://www.classiczcars.com/forums/topic/11635-installing-a-deck/#findComment-80354 Share on other sites More sharing options...
May 10, 200420 yr Author comment_80355 I need to cut plastic out, but that doesent matter cause my console is already cracked a bit near the ashtray, ill get a new one when i do an OEM restoration. Actually all the connections have been upgraded, cause the P.O had a stereo i think. I just want to know, what tool do i use to make clean cuts in the plastic? THANKS.P.S, I just went out to my car and connected the audio power cable into my new deck, and nothing at all happends, does the other plug need to be in also? i still need to change the plug over so it will fit into the pioneer. Link to comment https://www.classiczcars.com/forums/topic/11635-installing-a-deck/#findComment-80355 Share on other sites More sharing options...
May 10, 200420 yr comment_80392 a rotary saw(dremel) worked best for me. then file/sand the edges to suit.Usually on the modern radios, one power wire is for the amps & receiver, the other for clock/memory. Memory wire being always HOT, but low current (1 amp). read your info papers, it should tell you what you need. Link to comment https://www.classiczcars.com/forums/topic/11635-installing-a-deck/#findComment-80392 Share on other sites More sharing options...
May 10, 200420 yr Author comment_80397 Actually, i dont have information papers with it, my brother got it from a friend because he was getting a new one. Their are 11 wires with the pioneer plug, but only 6 in the original datsun wiring, so i need to firgure out which wires i dont need. Link to comment https://www.classiczcars.com/forums/topic/11635-installing-a-deck/#findComment-80397 Share on other sites More sharing options...
May 10, 200420 yr comment_80403 Quote Originally posted by Datsun-Fever Actually, i dont have information papers with it, my brother got it from a friend because he was getting a new one. Their are 11 wires with the pioneer plug, but only 6 in the original datsun wiring, so i need to firgure out which wires i dont need. Then try searching the manufacturer's website for the owner's/installation manual. You really need to figure out what all the wires are for FIRST, you can damage your unit by hooking up power to the wrong wire. Link to comment https://www.classiczcars.com/forums/topic/11635-installing-a-deck/#findComment-80403 Share on other sites More sharing options...
May 10, 200420 yr Author comment_80406 Ok, im looking right now, but isnt the power cord that black one with the metal tip? ^^^^^^ Thats the antenna right? yea i need help i found a manual. THANKS GUYS Link to comment https://www.classiczcars.com/forums/topic/11635-installing-a-deck/#findComment-80406 Share on other sites More sharing options...
May 10, 200420 yr Author comment_80412 Do you guys know where i can get a diagram of which wires are what? i know red and yellow are the power, but i need to match the DEH ones to my datsun wires, i dont want to mismatch the wires! Link to comment https://www.classiczcars.com/forums/topic/11635-installing-a-deck/#findComment-80412 Share on other sites More sharing options...
May 10, 200420 yr comment_80413 99.999 % of the time, the Black one is the Ground!Please don't fry your stereo. take your time and do the research Link to comment https://www.classiczcars.com/forums/topic/11635-installing-a-deck/#findComment-80413 Share on other sites More sharing options...
