Posted May 10, 200420 yr comment_80408 OK, someone smarter than me needs to help me here. I had my 240 in storage for 16 months. Ran great before I stored it. Took a bit, but I finally got it started this weekend only to find out that it will not go in gear now??pushing the shifter towards first makes the car rock forward a little. No grinding noise. Trying for reverse and you are grinding serious gears.Didn't do that before I stored it. Anybody have any idea what is up? I am guessing something with vacuum? But I know nothing about the working of the transmission. Link to comment https://www.classiczcars.com/forums/topic/11649-gear-shift-wont-engage/ Share on other sites More sharing options...
May 10, 200420 yr comment_80410 It's not your transmission but rather the hydraulic clutch system. Check the fluid level in the clutch master cylinder. Link to comment https://www.classiczcars.com/forums/topic/11649-gear-shift-wont-engage/#findComment-80410 Share on other sites More sharing options...
May 10, 200420 yr Author comment_80419 Yep, checked that and it was full??? Link to comment https://www.classiczcars.com/forums/topic/11649-gear-shift-wont-engage/#findComment-80419 Share on other sites More sharing options...
May 10, 200420 yr comment_80422 It's been years since I replaced my clutch slave cylinder so I can't remember many details of its operation. I think you should be able to see the actuating arm move when you (well, someone else) steps on the clutch. If it doesn't move then clearly the clutch is staying engaged hence the inability to shift. It may be that the reservoir is full but some air has entered the system. I'm sure someone else here can jump in with a more detailed diagnosis. Link to comment https://www.classiczcars.com/forums/topic/11649-gear-shift-wont-engage/#findComment-80422 Share on other sites More sharing options...
May 10, 200420 yr comment_80424 Before you try anything more in depth i would try bleeding the lines. instructions for this are in most any datsun shop bookif you dont have one lmk and i will post the directions for you Link to comment https://www.classiczcars.com/forums/topic/11649-gear-shift-wont-engage/#findComment-80424 Share on other sites More sharing options...
May 10, 200420 yr comment_80439 If the clutch pedal feels firm (at least the same as before storage) then the slave cylinder bore may have corroded and is not allowing piston to move. Pull the boot off of slave and inspect for corrosion pits or "blossums" Link to comment https://www.classiczcars.com/forums/topic/11649-gear-shift-wont-engage/#findComment-80439 Share on other sites More sharing options...
May 10, 200420 yr comment_80447 bet the clutch disc is stuck to the flywheel i have seen it before. roll the car to a safe place and put the car in 1st gear hold the brake and clutch and try to start it. it should release Link to comment https://www.classiczcars.com/forums/topic/11649-gear-shift-wont-engage/#findComment-80447 Share on other sites More sharing options...
May 11, 200420 yr Author comment_80479 Thanks all! I just read in a manual about the fly wheel freezing up when sitting. That was the deal, put it in gear start it, then let the clutch out slowly to "break" it. I had to tug on it with a tow chain to "break" the brakes too. Poor baby is a rust magnet if left alone too long! Link to comment https://www.classiczcars.com/forums/topic/11649-gear-shift-wont-engage/#findComment-80479 Share on other sites More sharing options...
May 11, 200420 yr Author comment_80481 NOT the fly wheel!The Driven plate sticking to the input shaft splines due to rust.G Link to comment https://www.classiczcars.com/forums/topic/11649-gear-shift-wont-engage/#findComment-80481 Share on other sites More sharing options...
