Recently Browsing 0
There are two oil senders on the right side of my 83 280ZX block that I am putting in my 240. The one part I threw away, a short sender switch with a fuel injector type (2 electrical pins) cnnnector is all that is keeping me from starting it up. It goes behind the oil filter (the other one is the canister that goes in front of the filter) and towards the top of the short block. Seems like it would be a oil temperture sender, but I can't find it anywhere on the microfiche at carfiche.com.
What the heck is it?
What is the nissan part #. I would get a plug, because I don't need the switch but the hole appears to be some funky pipe thread pitch (spec).
https://www.classiczcars.com/forums/topic/11653-what-is-the-second-oil-sender-on-f54-block/Share on other sites
