May 11, 200420 yr comment_80614 PVC tubing is the best material to use for homemade cold air induction. Lighter, cheaper, whiter! Link to comment https://www.classiczcars.com/forums/topic/11658-rare-custom-su-intake/?&page=2#findComment-80614 Share on other sites More sharing options...
May 11, 200420 yr comment_80615 Here's my .02 cents worth..........The idea is good but the exicusion is not!!! Not enough air volume within the tube for the two SU's. As said previously, look at those 90 degree air travel path turns. In fact if you think about it, the front carb would potentially have a low pressure area created at the mouth of the #1 carb as the air rushes across the opening.....similar to a syphon.....not good. Also, the guy says the brass conducts heat away quickly.....well, if it can conduct heat away quickly it can also heat up just as quickly.....another NG thing. The only way this item would work is if it was part of a positive pressure system (forced induction),!? As said previously, it looks like a boat part!!! But hey.....someone will buy it...you can count on it. If there are people dumb enough to try and sell their reject project then there are likely people who will buy it. I'll bet if he would have polished the brass it would already be sold!!! ROFL Link to comment https://www.classiczcars.com/forums/topic/11658-rare-custom-su-intake/?&page=2#findComment-80615 Share on other sites More sharing options...
May 11, 200420 yr comment_80616 I'm sorry, I can't help myself on this one!!! Since when do you WELD brass??? And what does the seller mean by calling it RARE???? As in not very well done? ROFL I'm guessing the seller is "fightyourself" based on his responce to the posts. Come on....................bring on the S_ _t flinging. Yeeeeeeehawwwwwwww!!!!!!!!!!!!!!!!!!! Link to comment https://www.classiczcars.com/forums/topic/11658-rare-custom-su-intake/?&page=2#findComment-80616 Share on other sites More sharing options...
May 11, 200420 yr Author comment_80620 SO HOW DOES THE THING CAME TOGETHER IF IT WASN'T WELTED TOGETHER? Link to comment https://www.classiczcars.com/forums/topic/11658-rare-custom-su-intake/?&page=2#findComment-80620 Share on other sites More sharing options...
May 11, 200420 yr comment_80623 Not a forced induction expert, but I think SU's have a problem with this sort of forced intake because of the float bowls.Nothing like an interesting EBAY ad to make conversation on a dull day....steve Link to comment https://www.classiczcars.com/forums/topic/11658-rare-custom-su-intake/?&page=2#findComment-80623 Share on other sites More sharing options...
May 11, 200420 yr comment_80629 Your on the money Steve regarding the SU's. I guess I should have been a little more specific with my explanation. I should have said.......based on the Ebay intake, excluding the use of SU carbs, it might work for a forced induction system! "fightyourself" is fighting with himself.......he still didn't get the comment about welding brass. You don't weld brass, you solder brass. It's a bonding process as opposed to a fusing process. Link to comment https://www.classiczcars.com/forums/topic/11658-rare-custom-su-intake/?&page=2#findComment-80629 Share on other sites More sharing options...
May 11, 200420 yr comment_80631 Ok, Tom, but if you brazed it and used a brass rod as your expendable, wouldn't that be welding?steve Link to comment https://www.classiczcars.com/forums/topic/11658-rare-custom-su-intake/?&page=2#findComment-80631 Share on other sites More sharing options...
May 11, 200420 yr Author comment_80647 forgive me 240ZX, I'll watch the terminology next time.but I do like the way everyone is responing to a ebay ad. it's great! Link to comment https://www.classiczcars.com/forums/topic/11658-rare-custom-su-intake/?&page=2#findComment-80647 Share on other sites More sharing options...
May 11, 200420 yr comment_80650 I think I'm going to buy it and ship a piece of it to each of you for your collection... You could polish it up and put it on your desk for a conversation piece!Come on, you know you want it......:stupid: Link to comment https://www.classiczcars.com/forums/topic/11658-rare-custom-su-intake/?&page=2#findComment-80650 Share on other sites More sharing options...
May 11, 200420 yr Author comment_80654 240ZX would like that polished and put it up his arse, so when people ask about it, he can tell them everything he know about brass and welding. Link to comment https://www.classiczcars.com/forums/topic/11658-rare-custom-su-intake/?&page=2#findComment-80654 Share on other sites More sharing options...
May 11, 200420 yr Author comment_80657 and about forced induction Link to comment https://www.classiczcars.com/forums/topic/11658-rare-custom-su-intake/?&page=2#findComment-80657 Share on other sites More sharing options...
May 12, 200420 yr comment_80666 Technically, however, wouldn't that be exhaust? (Mike, if you kill the previous two comments, kill this one too because it'll no longer make sense. Link to comment https://www.classiczcars.com/forums/topic/11658-rare-custom-su-intake/?&page=2#findComment-80666 Share on other sites More sharing options...
