I noticed a crossed wire in the Illumination circuit for the Water temperature/Oil pressure gauge a while back. Didnt think it was worth mentioning, but if there is a revision, then it can be added.
This colour wiring diagram is truly awsome. Thanks for all the effort Wayne.
I printed it on an extended A1 format and it hangs on the wall of my garage. So much better than the FSM.
Chas
Captain & Chas... I've made the edits, attached is Revision 'L'.
Thank you both for the kind words and the skillful quality control![ATTACH=CONFIG]73723[/ATTACH]
Here's the latest. It's Revision "M". It includes the two changes mentioned above (voltage regulator and illumination light in the Temp/Oil gauge):
1977 Color Wiring Diagram Version M.pdf
Wayne had asked for me to take a look at it and upload it if I got the chance. Never tried to attach a pdf before, so let's hope this works right!!
Thanks again Wayne!!
Edited by Captain Obvious
Uploaded newest version - M
  • 4 years later...
And for anyone getting ready to print out a big copy of revision "M" to hang on their garage wall.... Don't do that right now.
There have been some recently discovered issues in Rev "M" and I believe there will be a Revision "N" coming out soon to fix those issues.
So if you can hold off for a little bit, do so!
17 hours ago, wheee! said:
Maybe Mike can rename this thread “77 280Z colour wiring diagram” to avoid confusion with other years.
@Mike - It appears as though I cannot edit the title of this thread. Can you?
I was able to update the title in the download section, thank you for transferring 'ownership'
Thanks!
Thanks!
No problem. I edited the topic and updated the link to the file download in your first message.  I also added a link to this thread from the download details.  Thanks for supporting the file and keeping it updated!
  • 1 month later...
Now that all the (known) issues have been addressed and edited, I have updated Revision N to the download section.
Changes to Revision N
1) Fixed wire colors going to oil pressure sender and tachometer resistor.
2) Changed fusible link positions to reflect correct positions on vehicle.
3) Changed internal picture of alternator.
N77ZCAR-WIRING.pdf
