April 10, 200322 yr comment_33390 Originally posted by Ed The exhaust ports are square. I intend to keep the car as close to "Daily Driver" as possible. My advantage is that I have a 24 mile commute (one way). Seven of which are on a lonely country road with lots of curves. The rest is all freeway. My freeway has about 10-15 cars in 17 miles. And I've only seen 2 cops in the last 6 years. So there have been many an opportunity to let her go.I do want to increase horsepower without loosing the ability to drive into town and have to deal with 100 degree stop and go traffic. :mad: In other words I need to beat that Acura Integra! I already have the N42 head on it now but I can tell that the valve seals are gone. I'm really checking out my options for some more horsepower. Oh yea, did I forget to mention that new cam is going to go in at the same time (not sure which one though?). i know i am late to reply, but, ....i can't imagine the fun you are having just to commute to and from work..... i travel 44 miles one way for a few minutes shy of an hour in the morning and 1 and half hour (or more) in the pm at 60 fwy (L.A. to Walnut). Link to comment https://www.classiczcars.com/forums/topic/1184-head-swapping/?&page=2#findComment-33390 Share on other sites More sharing options...
April 24, 200321 yr comment_34970 A good combo is the NA F54 block (flat tops), and an N42(square), or N47 (round) head. The resulatnt CR is 9.82:1 with the stock gasket, and 10.08:1 with the Felpro. I just built one, and will be firing it up in the next month or so. I'll be tuning it on a dyno (track only car), so I'll post some dyno plots when I'm done tuning.Another option is to use the same block, but use a P79 or P90 head. But you will need to mill the head, and shim the cam towers to get the CR much above 8.5:1.BTW, the stock CR for the F54 turbo is 7.4:1. This is perfect for high boost applications, but that's a whole different thread...Pete Link to comment https://www.classiczcars.com/forums/topic/1184-head-swapping/?&page=2#findComment-34970 Share on other sites More sharing options...
