Posted May 23, 200420 yr comment_82420 Need drivers side exterior door handle..Thanks Bob Cummins Link to comment https://www.classiczcars.com/forums/topic/11867-driver-side-door-handle/ Share on other sites More sharing options...
May 24, 200420 yr comment_82490 Ive got two or three. Do you need the linkage or just the handle? Link to comment https://www.classiczcars.com/forums/topic/11867-driver-side-door-handle/#findComment-82490 Share on other sites More sharing options...
May 26, 200420 yr comment_82768 The door handles are interchangable from side to side on the 70-78 Z cars. Link to comment https://www.classiczcars.com/forums/topic/11867-driver-side-door-handle/#findComment-82768 Share on other sites More sharing options...
May 28, 200420 yr Author comment_83151 True. One need only put rod on correct end of handle depending on right or left door. Link to comment https://www.classiczcars.com/forums/topic/11867-driver-side-door-handle/#findComment-83151 Share on other sites More sharing options...
May 28, 200420 yr comment_83156 "The door handles are interchangable from side to side on the 70-78 Z cars."That also means that, depending on where it broke, you could switch sides!:classic: Will Link to comment https://www.classiczcars.com/forums/topic/11867-driver-side-door-handle/#findComment-83156 Share on other sites More sharing options...
May 29, 200420 yr comment_83167 Victoria British sells new door handles for $19.95 Link to comment https://www.classiczcars.com/forums/topic/11867-driver-side-door-handle/#findComment-83167 Share on other sites More sharing options...
May 29, 200420 yr Author comment_83271 Hi Mike-They were $19.95. Spring 2004 catalog list them at $24.95.!!! Link to comment https://www.classiczcars.com/forums/topic/11867-driver-side-door-handle/#findComment-83271 Share on other sites More sharing options...
August 25, 200420 yr comment_92583 Mike,Are the VB ones any good? I ordered a set for $24.95 apiece. Link to comment https://www.classiczcars.com/forums/topic/11867-driver-side-door-handle/#findComment-92583 Share on other sites More sharing options...
August 27, 200420 yr comment_92940 what year and modle car?????? Link to comment https://www.classiczcars.com/forums/topic/11867-driver-side-door-handle/#findComment-92940 Share on other sites More sharing options...
August 27, 200420 yr comment_92948 It's a 1978 280Z. Link to comment https://www.classiczcars.com/forums/topic/11867-driver-side-door-handle/#findComment-92948 Share on other sites More sharing options...
