May 25, 200420 yr comment_82682 I put up my experience on the twice pipes on the 'Reviews' section of the site about a year ago. Check it out for more detail if you want. I will say this, I love my twice pipe setup! Yes, it's pretty loud under full throttle! Is it ricer buzzy? Absolutely NOT! Will you like it? Who knows. Depends on what you want. I always say that it is a personal thing. Exhaust can give your car that last bit of personality. It's up to you what you want it to be. I wanted late '60's supercar sound. Got it! Car nuts always want to know what I have under the hood and comment on how great the car sounds. The rumble at idle is amazing....and I definately felt a difference in power after it was installed. FWIW, Zedguy Link to comment https://www.classiczcars.com/forums/topic/11877-how-loud-are-twice-pipes/?&page=2#findComment-82682 Share on other sites More sharing options...
May 25, 200420 yr comment_82684 I'm running a header, through 2 and 1/2 pipe, ending with a high flow muffler, and it's sounds great. (I should be running 3" though) Of course having a 3.0L with a very large cam probably helps with the sound.. Link to comment https://www.classiczcars.com/forums/topic/11877-how-loud-are-twice-pipes/?&page=2#findComment-82684 Share on other sites More sharing options...
