3-Car Comparison
Submitted by John Coffey
> I was at a 2 day autocross driving school over the weekend and I had
> chance to ride in and drive a number of Solo street prepared 240Zs.
> What surprised me was how each one drove differently based on how the
> owners had the cars setup. Here's what I observed:
> Car 1
> Springs: High rate springs, 25lb difference between front and rear
> with the rears stiffer.
> Shocks: Tokico Illumina 5 way, set for stiffer rear compression.
> Sway bars: Low rate both front and rear.
> Tires: 225/50-15 Yoko RS2s.
> Differential: LSD with very high breakaway torque.
> Car 2
> Springs: Low rate springs, 100lb difference between front and rear
> with fronts stiffer.
> Shocks: Tokico Illumina 5 way, set for stiffer front compression.
> Sway bars: High rate both front and rear.
> Differential: LSD with very low breakaway torque.
> Car 3
> Springs: High rate springs, 75lb difference between front and rear
> Sway bars: Medium rate both front and rear.
> Differential: Open.
> Car 1 was very balanced while under power and could be easily steered
> with the throttle. Very responsive to throttle inputs up to a point,
> too much throttle for too long would induce a spin. It did not like
> trail braking into a corner (the way Bondurant teaches it) and would
> respond with lots of understeer. Turning and braking would also
> induce a lot of understeer. Corner entrances would either be perfect
> or completely screwed up. The understeer could be fixed with a quick
> blip of the throttle and (rarely) with the brakes. Corner exits were
> the fastest of the 3 cars (if you did the entrance right) because you
> could get the power down early. This car wanted to be driven with the
> throttle.
> Car 2 was also very balanced while under power but was more difficult
> to steer with the throttle. Preferred to be steered with the brakes.
> It liked trail braking into a corner which was the most effective way
> to get the back end around. Understeer was prevalent but could easily
> be fixed with the brakes or a lot of throttle. Easy to get a good
> corner entrance. Corner exits were fast but had to be controlled a
> bit with the brake and throttle at the same time. Not too responsive
> to the throttle, you had to put your foot into it to get a reaction.
> This car seemed to have the typical 240Z handling traits. Overall
> balance but you needed to left foot brake to control the understeer.
> Car 3 was biased more towards oversteer especially under power in a
> corner. Responsive to gentle throttle inputs but with the open rear
> if you went to far, you were gone. Car had a razor edge between power
> oversteer and spinning. Understeer was common but could be controlled
> with trail braking or throttle. Car was responsive to trail braking
> but less so than Car 2. Corner entrances were fast and the car could
> be balanced through he corner pretty well. Corner exits were almost
> as fast as the other two cars but it was a result of carrying more
> speed through the corner. You had to wait a bit before putting the
> power down.
> Now... the question is, which of these cars had the fastest time of
> the day with the same driver? Let's hear the pundit's guesses...
Next post has the answer........
https://www.classiczcars.com/forums/topic/119-3-car-comparison/
Continued Article -- by John Coffey
> For those that are interested, here's the answer:
> Car 1 was the fastest with a time of 60.322 when driven by the driving
> instructor!
> But, Car 3 was second with a time of 60.389 and Car 2 was third with a
> time of 60.411 with the same guy driving them! Even in autocross
> those time differences are fairly small. The person who drove all
> three cars owns Car 2 so we can assume he got everything out of that
> car that he could. I own Car 1 and my best time of the day was a
> 61.312. I also drove Car 2 and my best time in that car was a 63.4xx.
> The owner of Car 3 had a best time of 59.7xx and he was the fastest of
> all the Z drivers. He didn't drive any of the other cars and was
> stuck in the 60.5xx range until he made a heroic last run of the day.
> What were the guesses from the two lists:
> Car 1 - 5 people
> Car 2 - 2 people
> Car 3 - No guesses
> Sorry, no prizes for the correct guesses.
> What do we learn from this? Probably that there is no one correct way
> to setup a suspension for autocross. A good driver can adapt to the
> capabilities and foibles of any car and quickly get the most out of
> it. There might be more ultimate potential in any one particular car,
> but it takes some time and practice to wring it out.
> Thanks for playing. We have some lovely parting gifts at the door...
