Posted May 26, 200420 yr comment_82852 I installed new 280z radiator that has two oil cooleror transmission oil coolder inlet and outlet.So,,,I popped up the idea that if I install the "perma-cool oil filter relacatiion kit and its hose/s which connect to the 280z radiator's trans oil cooler inlet and outlet, it would good idea? So, I don't have to buy an oil cooler and finding/driling from engne or oil pan?any thoght?just like my 240z, I am from japan too, what's heck Link to comment https://www.classiczcars.com/forums/topic/11922-oil-cooler-hose-from-remote-oil-filter/ Share on other sites More sharing options...
May 26, 200420 yr comment_82857 The trans cooler in the radiator wouldn't have passages that would flow the engine oil, as it is designed for a light viscosity oil such as transmission fluid. Not only that, but the oil pressure would almost certainly cause problems as the radiator isn't designed for that high a pressure with such a heavy oil.Better to get a relocation kit and do a proper engine oil cooler in front of the radiator. Link to comment https://www.classiczcars.com/forums/topic/11922-oil-cooler-hose-from-remote-oil-filter/#findComment-82857 Share on other sites More sharing options...
