Posted May 28, 200421 yr comment_83054 HI guy si just bought a 73 240z, the seats are the originals but now i am not sure if re the original year because the passenger has the lever to recline in the right (outside) and the drivers car has it in the right to (inside),but it dosent hve a function it looks stuck maybe rust, but could be that that seat was taken froma passenger car? Link to comment https://www.classiczcars.com/forums/topic/11949-both-seats-with-lever-on-the-right/ Share on other sites More sharing options...
May 28, 200421 yr comment_83055 Both seats should have the lever at the INSIDE (i.e. near the Trans Tunnel). Link to comment https://www.classiczcars.com/forums/topic/11949-both-seats-with-lever-on-the-right/#findComment-83055 Share on other sites More sharing options...
May 28, 200421 yr comment_83074 All my Z's have the seat recline lever on the side nearest the door. The passenger seat lever is on the right of the seat, the drivers seat lever is on the left of the seat. This is not correct? Vicky Link to comment https://www.classiczcars.com/forums/topic/11949-both-seats-with-lever-on-the-right/#findComment-83074 Share on other sites More sharing options...
May 28, 200421 yr comment_83075 Vicky is right the seat adjusters should be on the door side of the seats. I have never seen a car with the adjusters next to the tunnel. Link to comment https://www.classiczcars.com/forums/topic/11949-both-seats-with-lever-on-the-right/#findComment-83075 Share on other sites More sharing options...
May 28, 200421 yr comment_83079 I don't think the drivers seat is original. If you think about it, in many cases the drivers seat get a lot of abuse (because it always has a butt on it!!!) but a passenger seat can be left relatively untouched.Me thinks someone has had a worn-out drivers seat and at some point replaced it with a good passenger seat from another car. Link to comment https://www.classiczcars.com/forums/topic/11949-both-seats-with-lever-on-the-right/#findComment-83079 Share on other sites More sharing options...
May 28, 200421 yr comment_83082 Wouldn't the seat slider lever also be in the wrong position on richyboycaldos drivers seat if it truly is a passenger seat?Vicky Link to comment https://www.classiczcars.com/forums/topic/11949-both-seats-with-lever-on-the-right/#findComment-83082 Share on other sites More sharing options...
May 28, 200421 yr comment_83083 Quote Originally posted by Zrush Wouldn't the seat slider lever also be in the wrong position also on richyboycaldos drivers seat if it truly is a passenger seat? It would be if the seat was transplanted intact. The seats really are made up of several separate components. The seat bottom and seat back appear to be the same on both sides. The recline mechansism is part of one of the two hinge brackets that connect the seat back to the seat bottom. There are also two sliding brackets that mount the seat to the floor. One of these brackets has a sliding lever.If your driver's side seat was torn up and you had an extra passenger seat it would be easy enough to swap all of the brackets and it would look proper. Link to comment https://www.classiczcars.com/forums/topic/11949-both-seats-with-lever-on-the-right/#findComment-83083 Share on other sites More sharing options...
May 28, 200421 yr comment_83092 Quote Originally posted by Zrush All my Z's have the seat recline lever on the side nearest the door. The passenger seat lever is on the right of the seat, the drivers seat lever is on the left of the seat. This is not correct? Quote Originally posted by Alan Pugh Vicky is right the seat adjusters should be on the door side of the seats. I have never seen a car with the adjusters next to the tunnel. I submit for your inspection the attached screen print from the Nissan Z Parts Microfiche.I am surprised that that Vickys Z Store resto car has the seats placed as she describes. All of the 3 240Z's that I've owned since 1975 have had the seats placed as shown in the attachment. Link to comment https://www.classiczcars.com/forums/topic/11949-both-seats-with-lever-on-the-right/#findComment-83092 Share on other sites More sharing options...
May 28, 200421 yr comment_83094 Here's the attachment Link to comment https://www.classiczcars.com/forums/topic/11949-both-seats-with-lever-on-the-right/#findComment-83094 Share on other sites More sharing options...
May 28, 200421 yr comment_83096 I really can't tell anything from that diagram Carl. Tried to enlarge it but I couldn't. Went and looked at the owners manual on the 72 240Z and it shows the seat recline lever on the outside of the seat nearest the door (as they are on the car). Would be interested to have others check their owners manual to see what position they show the lever as being. This is quite interesting, no?Vicky Link to comment https://www.classiczcars.com/forums/topic/11949-both-seats-with-lever-on-the-right/#findComment-83096 Share on other sites More sharing options...
May 28, 200421 yr comment_83098 Quote Originally posted by Bambikiller240 I submit for your inspection the attached screen print from the Nissan Z Parts Microfiche. Interesting. Aren't there two different types of mechanisms? I thought the mechanism with the big fat knob that you twist was from the earlier cars yet that diagram shows it as up to July of 1973. Mine are the kind that have a small lever on the side of the seat bottom. According to the production changes list over at zhome.com these flip-forward seats were introduced around 10/71 (although mine are 9/71). Link to comment https://www.classiczcars.com/forums/topic/11949-both-seats-with-lever-on-the-right/#findComment-83098 Share on other sites More sharing options...
May 28, 200421 yr comment_83100 Quote Originally posted by Zrush I really can't tell anything from that diagram Carl. Tried to enlarge it but I couldn't. Went and looked at the owners manual on the 72 240Z and it shows the seat recline lever on the outside of the seat nearest the door (as they are on the car). Would be interested to have others check their owners manual to see what position they show the lever as being. This is quite interesting, no?Vicky Hmm, the attachment fills the entire screen on my computer, but maybe this one will work better.As for being interesting........not really (to me). As long as it is there and works what diff does it make (unless you are being judged at the convention)? Link to comment https://www.classiczcars.com/forums/topic/11949-both-seats-with-lever-on-the-right/#findComment-83100 Share on other sites More sharing options...
