OK...another question for you guys. Which air dam is the best? More specifically, urethane or fiberglass. I like the ones that MSA offers (minus that new one) but dont know for sure which type to get. I know noone personally who even has a z car let alone an air dam. Thanks for any advice.
https://www.classiczcars.com/forums/topic/11978-front-air-dam/
Hi
The polyurethane airdam would be more resilient and less prone to cracking if you were to bump something. important if your car is low in the front.
from what I know the middle of the urethane dams droop so you would have to fabricate a support to hold it up.
It would be awsome if someone made the BRE type "spook" in urethane, as well as the ZG flares, instead of fiberglass.
i highly recommend the urethane , replaced several before I learned , between speed bumps and curbs when parking its just not worth it , the right painter can add chemical to amek ti more elastic to it less likely to crack as it flexes
