Posted March 26, 200223 yr comment_4599 hey all-just wondering..i have a set of 32/36 dgv's on my 73 240however i just cant get it to run right-the engine is completely stock.does anyone have good set of su's they would like to trade??as far a i can honestly tell the carbs are ok..so i dunno, but i would like to get the car back to stock.i have both carbs,intake manifolds for them, and 2 sets of k&n filters..just let me knowthanks,kris Link to comment https://www.classiczcars.com/forums/topic/1199-weber-carb-swap/ Share on other sites More sharing options...
April 13, 200223 yr comment_5442 Make sure that the carbs are perfectly syncronized, by the linkage. Link to comment https://www.classiczcars.com/forums/topic/1199-weber-carb-swap/#findComment-5442 Share on other sites More sharing options...
April 13, 200223 yr comment_5451 SNOOTCHEES:If you don't get some interest in a couple of days, you might want to make a post over on www.zcar.com - there appear to be quite a few folks there who may be interested in DGVs. I think most of the folks here are SU fans like me, so the "interest base" may be pretty small. Link to comment https://www.classiczcars.com/forums/topic/1199-weber-carb-swap/#findComment-5451 Share on other sites More sharing options...
April 25, 200222 yr comment_6133 need help on my su carbs, rebuilt them, will not pass emissions test?? hc ppm was 560 beforerebuilt now 1826ppm co% was 4.65 now 9.68 any help?? 34legends@msn.com 1970 240 z:confused: Link to comment https://www.classiczcars.com/forums/topic/1199-weber-carb-swap/#findComment-6133 Share on other sites More sharing options...
December 16, 200222 yr comment_21009 hey snootcheez, are they dual or triple webers? i have a set of SUs on my 73 (but they are roundtops off a '72 so they are the good kind). let me know if you haven't found any solutions yet.email is: mike240@zilvia.netmike Link to comment https://www.classiczcars.com/forums/topic/1199-weber-carb-swap/#findComment-21009 Share on other sites More sharing options...
December 17, 200222 yr comment_21020 Where are you located???? No point pondering a swap if you are a million miles away.:classic: Link to comment https://www.classiczcars.com/forums/topic/1199-weber-carb-swap/#findComment-21020 Share on other sites More sharing options...
December 17, 200222 yr comment_21037 Downdrafts should be duals, I have the same setup and only get 15 MPG, so probably time for a rebuild on them. Link to comment https://www.classiczcars.com/forums/topic/1199-weber-carb-swap/#findComment-21037 Share on other sites More sharing options...
