Posted June 1, 200420 yr comment_83509 I recently got a steal on a 78 280z to restore ($100.00) it runs has some nasty body damage and other damage but I am in process of purchasing an Engine Hoist and Stand and was wondering if anyone could tell me what the Weight of the Engine/transmission together are for the hoist and just the engine itself.. I am new to restoring and have about 5 manuals on their way but would like to get this ordered before they get here. Thanks Link to comment https://www.classiczcars.com/forums/topic/12003-engine-weight/ Share on other sites More sharing options...
June 1, 200420 yr comment_83525 I dont know , but I just rented a cherry picker type and pulled the engine and trans as a unit no problem. I would guess 500 lbs. would be close. I am sure some one will come up with the actual weight. :classic: Link to comment https://www.classiczcars.com/forums/topic/12003-engine-weight/#findComment-83525 Share on other sites More sharing options...
June 1, 200420 yr comment_83527 I recently lifted a 280Z engine with tranny attached with my 1 ton chain hoist with no problems. Since the entire car isn't that much over a ton (the early 240Z) I don't think anything larger would be necessary. 500 pounds should be about right -- maybe a little on the high side. After taking the auto tranny off I lifted it w/out hoist into a wheelbarrow, but don't recommend it. Just didn't want to unhook the engine from the hoist at that time. Gary Link to comment https://www.classiczcars.com/forums/topic/12003-engine-weight/#findComment-83527 Share on other sites More sharing options...
June 1, 200420 yr comment_83570 Originally posted by GaryZ240 I lifted it w/out hoist into a wheelbarrow Damn Gary, you lifted a loaded L28 by yourself with no hoist? I don't want to ever wizz you off!! LOL Chris Link to comment https://www.classiczcars.com/forums/topic/12003-engine-weight/#findComment-83570 Share on other sites More sharing options...
June 1, 200420 yr comment_83580 No Chris, just the tranny. I may be crazy, but I'm not insane. :stupid: My days of deadlifting anything even near half the weight of the L28 are long gone, if they even ever existed. Link to comment https://www.classiczcars.com/forums/topic/12003-engine-weight/#findComment-83580 Share on other sites More sharing options...
June 1, 200420 yr comment_83581 L28E engine 200 kgs/440 lbsFS5C71B gearbox 40 kgs/90 lbs///Thomas Link to comment https://www.classiczcars.com/forums/topic/12003-engine-weight/#findComment-83581 Share on other sites More sharing options...
June 2, 200420 yr comment_83678 Hey Gary, my mistake, mis-read your post. I too have lifted an auto tranny and a bare L24 block but like you those days are over!:disappoin Chris Link to comment https://www.classiczcars.com/forums/topic/12003-engine-weight/#findComment-83678 Share on other sites More sharing options...
June 2, 200420 yr Author comment_83735 Thanks everyone.. well I just picked up a 1000lb engine stand and a 2 ton hoist for the paltry sum of 120 dollars at a local shop.. so I am ready to disassemble and see what kind trouble I can get in. You will probably be seeing my name a lot in the next few months.. Link to comment https://www.classiczcars.com/forums/topic/12003-engine-weight/#findComment-83735 Share on other sites More sharing options...
June 2, 200420 yr comment_83740 Hey Splice, good luck with your project. Be safe and make sure you secure the motor to the hoist and then the stand. That long motor can really wobble on an engine stand. I added bracing to my stand, seemed to help with stability. Much luck, Chris Link to comment https://www.classiczcars.com/forums/topic/12003-engine-weight/#findComment-83740 Share on other sites More sharing options...
June 13, 200420 yr comment_84921 be sure to use hardened bolts on the engine stand. :classic: Link to comment https://www.classiczcars.com/forums/topic/12003-engine-weight/#findComment-84921 Share on other sites More sharing options...
June 20, 200420 yr comment_85781 Had my L28 on a 750 engine stand much of last Winter,and felt like it was "sagging" 'bout 2 months in....so braced front of engine block with 2 x 4 Just in Case !!!Don't want it snapping off the stand and hitting the floor..or my toes !! 1000lb engine lift is fine for both engine and tranny.Good luck with project. Link to comment https://www.classiczcars.com/forums/topic/12003-engine-weight/#findComment-85781 Share on other sites More sharing options...
June 20, 200420 yr comment_85783 Where can one get a stand AND a hoist for 120? Everyplace I look wants 200 just for the hoist, and I can't rationalize spending that much for a part I'll use twice... Link to comment https://www.classiczcars.com/forums/topic/12003-engine-weight/#findComment-85783 Share on other sites More sharing options...
