Email logins are now active ×
Engine Weight?
Splice
I recently got a steal on a 78 280z to restore ($100.00) it runs has some nasty body damage and other damage but I am in process of purchasing an Engine Hoist and Stand and was wondering if anyone could tell me what the Weight of the Engine/transmission together are for the hoist and just the engine itself.. I am new to restoring and have about 5 manuals on their way but would like to get this ordered before they get here.
Thanks
I dont know , but I just rented a cherry picker type and pulled the engine and trans as a unit no problem. I would guess 500 lbs. would be close. I am sure some one will come up with the actual weight. :classic:
I recently lifted a 280Z engine with tranny attached with my 1 ton chain hoist with no problems. Since the entire car isn't that much over a ton (the early 240Z) I don't think anything larger would be necessary. 500 pounds should be about right -- maybe a little on the high side. After taking the auto tranny off I lifted it w/out hoist into a wheelbarrow, but don't recommend it. Just didn't want to unhook the engine from the hoist at that time. Gary
:finger: No Chris, just the tranny. I may be crazy, but I'm not insane. :stupid: My days of deadlifting anything even near half the weight of the L28 are long gone, if they even ever existed.ROFL
Thanks everyone.. well I just picked up a 1000lb engine stand and a 2 ton hoist for the paltry sum of 120 dollars at a local shop.. so I am ready to disassemble and see what kind trouble I can get in. You will probably be seeing my name a lot in the next few months..
Hey Splice, good luck with your project. Be safe and make sure you secure the motor to the hoist and then the stand. That long motor can really wobble on an engine stand. I added bracing to my stand, seemed to help with stability.
Much luck,
Chris
Had my L28 on a 750 engine stand much of last Winter,
and felt like it was "sagging" 'bout 2 months in....
so braced front of engine block with 2 x 4 Just in Case !!!
Don't want it snapping off the stand and hitting the floor..
or my toes !!
1000lb engine lift is fine for both engine and tranny.
Good luck with project.
