need 71 240 parts
Zdreamer
  • 4 weeks later...
  • 4 weeks later...
Are you planning on straight stock? I used the 280 side to aluminum pieces they are smooth as where the old ones had that ridge that held dirt. Are the arm rest missing or torn or just broken thru the hole that holds the bolt. If its just the bolt hole I can tell you a fix.
  • Who's Online   1 Member, 0 Anonymous, 661 Guests (See full list)
