Posted June 2, 200420 yr comment_83677 This might have been covered before, but can any one tell me if a brake booster can be tested off the car? like with a vacuum gun? or does it need to be on the car with the engine running for any tests?I have 2 early 1970's servos, one was working when it was taken off ( about 13 years ago :classic:) the other is an unknown but is probably the original from my my 1970 so 34 years old!!!Or given the age of the components should I just get a rebuilt one?thanks for any helpAndrew Link to comment https://www.classiczcars.com/forums/topic/12030-brake-booster-testing-off-car/ Share on other sites More sharing options...
June 2, 200420 yr comment_83693 Yes, and Yes. :devious: Link to comment https://www.classiczcars.com/forums/topic/12030-brake-booster-testing-off-car/#findComment-83693 Share on other sites More sharing options...
June 9, 200420 yr comment_84537 well i had to put a larger booster for sub woofers i putted in yesterday i goes thump thump a lot better now hopefully your booosters treat you well. Link to comment https://www.classiczcars.com/forums/topic/12030-brake-booster-testing-off-car/#findComment-84537 Share on other sites More sharing options...
June 9, 200420 yr comment_84546 Quote Originally posted by kyleh well i had to put a larger booster for sub woofers i putted in yesterday i goes thump thump a lot better now hopefully your booosters treat you well. What are you talking about? Brakes or stereos???:stupid: :stupid: Link to comment https://www.classiczcars.com/forums/topic/12030-brake-booster-testing-off-car/#findComment-84546 Share on other sites More sharing options...
