Posted June 2, 200420 yr comment_83697 I have a '75 280z with A/C. I can't control the fan speed because the plastic wheel that is attached to the switch is broken.I need the round plastic assembly that gets rotated by the teeth of the blower speed control lever. Hopefully that is specific enough.While I'm at it, I could use a dome light as well.Thanks,George Link to comment https://www.classiczcars.com/forums/topic/12033-75-ac-blower-control-dome-light/ Share on other sites More sharing options...
June 2, 200420 yr comment_83713 I had the same thought on my 78 when the plastic lever that controls opening and closing of the vent broke on mine. Much easier to change out the whole control unit since you have to remove it anyway. Link to comment https://www.classiczcars.com/forums/topic/12033-75-ac-blower-control-dome-light/#findComment-83713 Share on other sites More sharing options...
June 2, 200420 yr Author comment_83715 I got my hand back there enough to get the broken piece off. I can get a wrench on the nut from the front such that I could make the swap without taking out the whole unit.So if I can get just the piece I need, I'll be good to go.George Link to comment https://www.classiczcars.com/forums/topic/12033-75-ac-blower-control-dome-light/#findComment-83715 Share on other sites More sharing options...
June 3, 200420 yr Author comment_83835 I have found a source for both my parts, thanks.George Link to comment https://www.classiczcars.com/forums/topic/12033-75-ac-blower-control-dome-light/#findComment-83835 Share on other sites More sharing options...
