I have a '75 280z with A/C. I can't control the fan speed because the plastic wheel that is attached to the switch is broken.
I need the round plastic assembly that gets rotated by the teeth of the blower speed control lever. Hopefully that is specific enough.
While I'm at it, I could use a dome light as well.
Thanks,
George
I had the same thought on my 78 when the plastic lever that controls opening and closing of the vent broke on mine. Much easier to change out the whole control unit since you have to remove it anyway.
I got my hand back there enough to get the broken piece off. I can get a wrench on the nut from the front such that I could make the swap without taking out the whole unit.
So if I can get just the piece I need, I'll be good to go.
George
