Hey guys, i am trying to get all of the electrical work done (while i wait for the pans to get welded) and i have big problems. When the car is on acc i turn the lights on, and the side lights and the two orange front ones go on and just stay on, the front headlights dont go on at all. Also, the left and right signal switch doesent seem to be working, i move it up or down but the signal lights dont do anything. (plus they are on, just not flashing). Any ideas? Thanks.
https://www.classiczcars.com/forums/topic/12063-outside-light-problems/
The last thing you mention (turn signals) sounds like a bad flasher unit. How do your headlights/marker lights act when the key is in the lock or off position? If they still act the same as you described, then the problem is in the light switch/turn signal stalk itself. I'm assuming that you've checked the fuses.
Yea, same thing even if its on lock or off, as long as the battery is connected, i just turn that switch on the right side of the console. So do you have any advice as to how i would fix it? thanks.
