Todays stupid question ;)
gealicpride
I knew at some point stands would be mentioned. I have ramps but no stands and the ramps don't give me enough clearance. I'm not afraid of my car but don't want to get crushed either trying to loosen that bolt. Then again it's parked facing out so if I get it jackeh high enough I might be able to place the ramps let her down and just shimmy under it from the front. Is there anything on the front of the car...any metal strong enough for me to jack it up?
Jack it up unfer the frontcross member(from the bottom, ahead of the oil pan, after the radiator support-the front suspension is located by it!) If my explanation isn't clear, let me know, and I will post a picture-don't get under the car with out stands-cinderblocks do not count!!!!
Will
I agree, Jack it up at the front crossmember, right in the middle of the car just in front of the oil pan. If you look there is what appears to be a small skid plate about a 5 inch square. The frame rails are not a good idea because it is basically a single layer of metal. If you were to jack it up by the frame rails your rails would end up looking like a piece of aluminium foil that went through the washing machine. Even when you put the jack stands under there place them where the metal is the thickest, right behind the T/C rod. Or put a piece of wood between the jack stand and the rail.
