My 280 IT car is approx. 56 inches measured at the center of the tires. 240 should be the same but the tire width will differ. I could measure the distance between the rail of my trailer, but it will have to wait till daylight.
Or do you want the overall width?
https://www.classiczcars.com/forums/topic/1211-dimensions/#findComment-4679
thunderstreak,
Follow this link: http://www.240z.org/forums/showthread.php?s=&threadid=1937
I posted a file of the body dimensions for a 240 from the factory manual. Dimensions are in millimeters.
I hope this helps.
https://www.classiczcars.com/forums/topic/1211-dimensions/#findComment-4700
Just as a side note, my ITS 280 with 14x7 zero offset wheels and 225/60's measure about 65 1/2 inches to the outside of the tires, so you will be close. My trailer has 78 inches between the fenders(old homemade trailer) so I never had a problem there, but it was close on the inside width between the rails.
https://www.classiczcars.com/forums/topic/1211-dimensions/#findComment-4701
