Back Disc Brakes
dfr867
That's a common answer around here. You'll find many topics have been discussed numerous times. However, Gema's answer wasn't very helpful since the search function (at least on my home and work computer) haven't worked since the upgrade on this site a few weeks back. Hopefully it will indeed be the right swap soon, so you can find info on the brake swap. Good luck. Gary
I belive the car is the 240sx use its brake calipers with adaptor plates , then u use 280zx rotors , I will search for the link , there is a company that makes the plate as well as the whole set for z cars
FYI to everyone:
Search DOES still work, however you cannot access it from the Home page. You have to start from the "FORUMS" tab, then click on "Search".
....and recommending use of the SEARCH function is a valid response to questions that have bee discussed ad nausium.
The Lord helps those who help themselves (when possible).
That link to modern motersports is fine and dandy but you could do a similar upgrade with nissan parts for less money. You'll find the most detailed info by searching this site but to sum it up you need a set of rear caliper brackets from a Nissan Maxima and 2 different sets of calipers will work. Choose from the 240SX setup or 280ZX setup. Probably searching the site for "maxima bracket" will give you all the info you need.
Big rear brake conversion
240sx 4 x 4 1/2 lugs
79-81 280zx master 15/16
89-98 240sx calipers and hangers
84-85 300zx rear rotors 4x4 1/2 lug pattern
86-80 FWD maxima rear dust shields and hub brackets both bored, cut and welded with correct offset.
rear axles must be removed to install brackets
make brake cable extenders
Small rear brake conversion
82-53 280zx rear calipers and hangers
82-83 280zx rear rotors
86-89 FWD maxima rear dust shields and hub brackets ... cut and welded with correct off set
OR 80-84 nissan 810, maxima sedan rear brackets that have floating dust shield
rear axle must be removed to install bracket
Big rear brake conversion 280zx
82-83 280zx calipers and hangers
84-85 300zx rear rotors 4 x 4 1/2 lugs
86-89 FWD maxima rear dust shields and hub brackets ... bored cut and welded with correct off set
bone stock small rear brake conversion Maxima 4x4 1/2 lugs
79-81 280zx rear calipers and hangers
79-81 280zx rotors 4x4 1/2 lugs
80-84 810, maxima sedan rear brackets that have screw on dust shields
rear axles must be pulled on all to install brackets
from brokebolt ... he allowed me to save it and repost it ... Mike is a nice guy. went out of his way to make sure that i got all the right info to make my decision.
hope this info helps
wayne
