Posted June 9, 200420 yr comment_84558 I have a p90 head that is warped by 5/1000ths and I'm getting it shaved by 1/8000ths. Will this head work on my L24 block? What would my compression be and which head gasket thickness should I use? Link to comment https://www.classiczcars.com/forums/topic/12129-p90-head-on-a-l24-block/ Share on other sites More sharing options...
June 10, 200420 yr comment_84605 check out the below link and have a play....http://www.zcarclub.com.au/project/eng_build/lengine.zip Link to comment https://www.classiczcars.com/forums/topic/12129-p90-head-on-a-l24-block/#findComment-84605 Share on other sites More sharing options...
