Posted March 28, 200223 yr comment_4699 This file is to be opened in Adobe Acrobat. This is a copy of the overall body dimensions for the 240Z from the factory shop manual. All dimensions are in millimeters. To convert (mm) to (in) multiply by .03937.chassisfrommanual8bmpwocomp.zip Link to comment https://www.classiczcars.com/forums/topic/1214-240z-body-dimensions/ Share on other sites More sharing options...
April 7, 200223 yr comment_5123 Thanks kmac for the download. I can't open it though . It says it cannot find ACRORD32.exe What file is this?? I have Adobe Acrobate if thats what it is? Any ideas? THANKS!! Link to comment https://www.classiczcars.com/forums/topic/1214-240z-body-dimensions/#findComment-5123 Share on other sites More sharing options...
April 8, 200223 yr Author comment_5140 240Z,I tried downloading this my self and didn't have any problems. The zip file only contains one file, the dimensions file. But I did do a search on my hard drive of the file you say is missing. It is a file neccessary for Acrobat. I would try reloading a version of Acrobat again and see if that helps. I'm running version 5.0, btw.If you need more help, send me a private message and I'll try to do what I can. Link to comment https://www.classiczcars.com/forums/topic/1214-240z-body-dimensions/#findComment-5140 Share on other sites More sharing options...
June 19, 200222 yr comment_9076 I can't open it though . It says it cannot find ACRORD32.exe George, It's telling you that you don't have Acrobat Reader installed. (acrord32.exe) Go download it and install on your computer. http://www.adobe.com/products/acrobat/readstep2.html Link to comment https://www.classiczcars.com/forums/topic/1214-240z-body-dimensions/#findComment-9076 Share on other sites More sharing options...
