Posted June 11, 200420 yr comment_84790 I don't know why my engine keep's running after I shut it off. I've check the timing, fuel mixture, exaust (for leaks), and vacume leaks, and I can't find any thing wrong. But it still runs after I turn the key off. It also runs backwards!!!! What the hell is going on?Rock on Z peopleMatt- Link to comment https://www.classiczcars.com/forums/topic/12162-engine-run-on/ Share on other sites More sharing options...
June 11, 200420 yr comment_84796 What kind / year of car do you have?- Jeff Link to comment https://www.classiczcars.com/forums/topic/12162-engine-run-on/#findComment-84796 Share on other sites More sharing options...
June 11, 200420 yr Author comment_84797 Sorry, I left that little part out... L-28 F54 block with flat top pistons .020 over bore, N42 head with a performance came ( 460 lift 273 duration), performance springs new rocker arms, steel valve seats three angle valve job, HKS 2mm head gasket, MSA header, 2.5 inch exaust dumping into a dyno max muffler, round top SU rebuilt carbs with SM needles, electronic distributer, Stock air cleaner box with K&N air cleaner. I think that is every thing. Just incase you were wondering I have about a 9.2:1 compression ratio. that is what the HKS 2mm head gasket is for it lowers the CR so I can use regular pump gas. Matt- Link to comment https://www.classiczcars.com/forums/topic/12162-engine-run-on/#findComment-84797 Share on other sites More sharing options...
June 11, 200420 yr comment_84800 That list would make me think it may run hot -- does it?Be sure the timing is set correctly for your use. Check the fuelfloat level and see if it is closing all the way when the bowels are full.( hot engine .. alittle more gas .. run on.. even without spark)- Jeff Link to comment https://www.classiczcars.com/forums/topic/12162-engine-run-on/#findComment-84800 Share on other sites More sharing options...
June 11, 200420 yr Author comment_84817 The engine runs really cool. I'd guess about 160 F on a hot day, I put in a new radiator with the engine build. As far as the carb floats I check thoes before I put them on the car so they should be fine. I just double checked the timing today and its fine (about 13 degrees btc). Any other reasons that is might do that? thanks for the help JeffMatt- Link to comment https://www.classiczcars.com/forums/topic/12162-engine-run-on/#findComment-84817 Share on other sites More sharing options...
June 11, 200420 yr comment_84818 Is it deisling? (bad speller)If so then its your timing. I would check that next. Link to comment https://www.classiczcars.com/forums/topic/12162-engine-run-on/#findComment-84818 Share on other sites More sharing options...
June 11, 200420 yr comment_84820 I'd guess the timing is too advanced. 13 BTDC seems a lot to me. Link to comment https://www.classiczcars.com/forums/topic/12162-engine-run-on/#findComment-84820 Share on other sites More sharing options...
June 11, 200420 yr Author comment_84823 Yep its deiseling... I just checked the timing today. I have it as advanced as it will go with out "pinging" under heavy load. That's what the guys at MSA recomendedMatt- Link to comment https://www.classiczcars.com/forums/topic/12162-engine-run-on/#findComment-84823 Share on other sites More sharing options...
June 12, 200420 yr comment_84834 It costs you nothing to lower it and see if that helps. Link to comment https://www.classiczcars.com/forums/topic/12162-engine-run-on/#findComment-84834 Share on other sites More sharing options...
June 12, 200420 yr Author comment_84838 good point Carl, I'll give it a try!Matt- Link to comment https://www.classiczcars.com/forums/topic/12162-engine-run-on/#findComment-84838 Share on other sites More sharing options...
