Recently Browsing 0
I just finished installing a replacment turn signal switch & lever. After replacing the plastic 2 piece steering column cover I noticed that the opening where the lever comes out seems seems a lot larger then needed. The lever I replaced had cruise control on it so it was similar to the wiper /lights lever and hid the opening completely. My long winded question is: was there a rubber piece similar to a shifter boot or grommet in this area?
Thanks,
Greg
https://www.classiczcars.com/forums/topic/12213-turn-signal-leverrubber-insert/Share on other sites
