Trumpets
Deus Ex
Hey Guys,
I was wondering if anyone had a rough idea on the power increase or effects of putting trumpets on my Triple Webber L28. I have been told that they do in fact make more power/torque depending on the length of the trumpets but as such i havent actully talked to anyone who uses them.
Also, what do you use for filters? Oil Socks?
Thanks
I'm not sure of the power increase, but I did notice a difference in the idle and exceleration once I installed the trumpets.
A buddy of mine races Z's with mikunis like mine and he is the one that suggested I get some.
They affect the air flow into the carbs by making a smooth transition into the carbs.
As to filters I installed the trumpets in a set of K&N filters.
The intake is short enough to allow filters that will let me do that.
There are some foam filters that can be stretched over the trumpets, but they get dirty fast.
Good luck.
Originally posted by d3c0y
Short ones will also have better throttle response.....
shut up jake...! just put a rb20 in and save me alot of head aches matt:stupid:
