June 16, 200420 yr comment_85290 Originally posted by kmack I'm currently running a 280ZX radiator ('82 to be specific, but they're all the same) in my 240Z. Only two mods were required. Hey kmack, does that radiator hang down below the beam where the horns mount? Just curious as I almost did this conversion. Thanks, Chris Link to comment https://www.classiczcars.com/forums/topic/12217-list-of-suitable-parts-from-other-makes/?&page=3#findComment-85290 Share on other sites More sharing options...
June 16, 200420 yr comment_85291 Yes, it hangs down by about 2-1/2". That's the down side. With a stock valance in place, you can see the bottom of the radiator and you have to be careful about not parking up close to concrete parking stops or curbs. If you have an airdam, it would hide the radiator. Link to comment https://www.classiczcars.com/forums/topic/12217-list-of-suitable-parts-from-other-makes/?&page=3#findComment-85291 Share on other sites More sharing options...
June 16, 200420 yr comment_85295 Thanks kmack, doesnt sound too bad. Chris Link to comment https://www.classiczcars.com/forums/topic/12217-list-of-suitable-parts-from-other-makes/?&page=3#findComment-85295 Share on other sites More sharing options...
June 26, 200420 yr comment_86593 Any oversized valves perhaps?? Link to comment https://www.classiczcars.com/forums/topic/12217-list-of-suitable-parts-from-other-makes/?&page=3#findComment-86593 Share on other sites More sharing options...
June 30, 200420 yr comment_86994 Originally posted by Bambikiller240 Any idea what a Pintara is called in the US? just by looking at it it kinda resembled a stanze maybe?? i dunno, just guessin.. Link to comment https://www.classiczcars.com/forums/topic/12217-list-of-suitable-parts-from-other-makes/?&page=3#findComment-86994 Share on other sites More sharing options...
September 11, 200420 yr comment_94750 Carl working on his wipers today reminded me of a "suitable part from other makes" part on my car. Western Star truck wiper washer pump. #62912-3401. Fits the stock resevoir and requires minor electrical mods. For those of you that arent concerned with originality this part has worked well for me. Chris Link to comment https://www.classiczcars.com/forums/topic/12217-list-of-suitable-parts-from-other-makes/?&page=3#findComment-94750 Share on other sites More sharing options...
September 11, 200420 yr comment_94771 Western Star truck wiper washer pump. #62912-3401. Fits the stock resevoir and requires minor electrical mods. For those of you that arent concerned with originality this part has worked well for me. ChrisYou can also get a Trico #11-601, which is labeled as a Honda replacement pump, it is exactly the same pump as the stock '70 - '73 windshield washer pump. The one exception is the connections, but if you have your old pump you'll see that the BLK wire (neg) has a FEMALE connector, and the Trico 11-601 has a MALE connector. It takes about 2 minutes to solder the correct type of connector onto the new pump.(Thanks Chris, I've added your info to my database of useful information.) Link to comment https://www.classiczcars.com/forums/topic/12217-list-of-suitable-parts-from-other-makes/?&page=3#findComment-94771 Share on other sites More sharing options...
September 13, 200420 yr comment_94935 Yes, it hangs down by about 2-1/2". That's the down side. With a stock valance in place, you can see the bottom of the radiator and you have to be careful about not parking up close to concrete parking stops or curbs. Wish I had known this earlyer. I had to hunt down a new/ used drain plug because I snaped the old one in two. The other half was still in the radiator. This really sucked. Link to comment https://www.classiczcars.com/forums/topic/12217-list-of-suitable-parts-from-other-makes/?&page=3#findComment-94935 Share on other sites More sharing options...
September 13, 200420 yr comment_94962 Western Star truck wiper washer pump. #62912-3401. Fits the stock resevoir and requires minor electrical mods. This is also assuming that your reservoir is still in good enough shape to handle prying the old pump out and squeezing a new one back in. I've been through 2 already where the plastic was too brittle and it crumbled in my hand! :dead: Link to comment https://www.classiczcars.com/forums/topic/12217-list-of-suitable-parts-from-other-makes/?&page=3#findComment-94962 Share on other sites More sharing options...
September 13, 200420 yr comment_94965 This is also assuming that your reservoir is still in good enough shape to handle prying the old pump out and squeezing a new one back in. I've been through 2 already where the plastic was too brittle and it crumbled in my hand! :dead:Presumably caused by the Texas heat? In cooler climes mine 'seem' to be OK after 30+years. Link to comment https://www.classiczcars.com/forums/topic/12217-list-of-suitable-parts-from-other-makes/?&page=3#findComment-94965 Share on other sites More sharing options...
September 13, 200420 yr comment_94967 Presumably caused by the Texas heat? In cooler climes mine 'seem' to be OK after 30+years.Yes, the "wonderful" Texas heat ( :stupid: ) can do strange things to plastic. From turning it into a fragile, brittle little piece of no longer usable car-art, to actually stretching it and causing longe hair-line cracks. It doesn't help that the reservoirs were made kind of thin to begin with. Link to comment https://www.classiczcars.com/forums/topic/12217-list-of-suitable-parts-from-other-makes/?&page=3#findComment-94967 Share on other sites More sharing options...
September 13, 200420 yr comment_94968 Nissan bluebird not sure exact years but early 80's type has an electronic fuel pump which is good for a carb'd Z. pumps between 3-4 PSI . Link to comment https://www.classiczcars.com/forums/topic/12217-list-of-suitable-parts-from-other-makes/?&page=3#findComment-94968 Share on other sites More sharing options...
