Carbs
Yes they are all Hitachi made SU copies, even the flat tops. Bill, if you have round tops on an L26 it was converted. Without even knowing it you a right on another point. It is generally accepted that 260Z's were only made for the 1974 model year, usually reffered to as early or late (small vs big bumpers). But I have seen 260Z's with build dates as late as 11/74 and they are registered as 75's. I guess they ran behind on the development of the 75 280Z.
Originally posted by billramsey2002
Well im not sure the Engine came out of the 260. It was giving to me in a trade.
We found the numbers that lead me to think it is a L26. Ill post the # here later
Engine ID number should start with: L24, L26 or L28
If you do have the "round-top" carbs on the engine, you're headed in the right direction.
Round-top meaning that the transition from the horizontal top surface of the carb dome to the vertical side surface has a radius to it, not a sharp edge. For those reading that may not know.
Yeah mine are round tops im pretty sure. I didnt know the difference untill now thanks kmack.
It is a L26 engine. So i guess the 260zs had round toppers on em.
The motor that came with the trade has a bad block. The cylender walls are pitted somthing bad.
I was given another motor that dodint have intake or carbs. Is a L26 from a 74.
Im learning thease things just learning slow:stupid:
The 260's originally came with flat tops. Here is a picture of the roundtops on my car:
http://www.geocities.com/vintagericeracing/159.html
Round-tops have the float bowls attached to the lower side of the main carb body. The flat-tops, have the float bowls integrated into the bottom of the carb body. Plus they are much bigger than the round-tops.
And we all had to learn about these things at one point or another. Hell, I didn't know the difference in carbs until after I already had the flat-tops running on my old spare motor from a junk '73!! Talk about a waste of time!:tapemouth :stupid:
No one here will criticize you for asking questions. That's how you learn. Before you know it, you'll be the one answering someone else's questions. We've all been there.
Bill said: "So i guess the 260zs had round toppers on em"
Stephen is right Bill, no 260Z ever had round tops from the factory. Has to have been converted.
Here's a picture of the flat top set up.
Notice the square throats where the air cleaner bolts up.
Gee, thanks a lot Chris.....seeing that picture sent shivers down my back as I remembered rebuilding those damned boat-anchors so many years ago! :tapemouth :tapemouth :sick: :tapemouth
To think, I actually had them working pretty good. Live and learn
Hey Kmack, gives me the heebie jeebies too, I have a set at home on a shelf. I curse them every time I walk by.LOL LOL LOL
Then I look at the ztherapy roundies on my 73 with the milled shafts and roller bearings and just smile!!!:classic:
Chris
From the pics mine look like round tops. I will post a pic o them when i get a bat for the digi.
Kmack i have been criticized for asking dumb questions.LOL
remmember i was wondering the common fusty spots in a z:stupid: total no brainer that day!
  • Who's Online   1 Member, 0 Anonymous, 269 Guests (See full list)
