Posted March 31, 200223 yr comment_4801 Does mikuni still make a carb setup for the Z? Also would 3.1L running between 10 /10.5 to 1 compression with SU and SM needles be a good setup? (Carb flow and run on 93 octane gas?) Thanx Link to comment https://www.classiczcars.com/forums/topic/1240-carb-questions/ Share on other sites More sharing options...
April 1, 200223 yr comment_4820 I would suggest contacting the guys at www.ztherapy.com they specialize in carbs for the Z and are going to be able to help you with advice and parts.Have a good night! Link to comment https://www.classiczcars.com/forums/topic/1240-carb-questions/#findComment-4820 Share on other sites More sharing options...
April 2, 200223 yr comment_4862 Here is a e-mail address of a Z-driver z-runner@twave.net he is known as the 12 sec dude in other areas . He turns the 1/4 in 12sec and he is running SUs maybe he can answer your questions . Best of luck to ya. Link to comment https://www.classiczcars.com/forums/topic/1240-carb-questions/#findComment-4862 Share on other sites More sharing options...
April 2, 200223 yr Author comment_4867 Thanx for the replies. I've e-mailed Ztherapy and am waiting for an answer. I'll try him too. Link to comment https://www.classiczcars.com/forums/topic/1240-carb-questions/#findComment-4867 Share on other sites More sharing options...
April 3, 200223 yr comment_4934 Try this link. wwwmalvernracing.com I think they still carry Mikuni/Solex carbs for Z's. Won't be cheap though........... Link to comment https://www.classiczcars.com/forums/topic/1240-carb-questions/#findComment-4934 Share on other sites More sharing options...
