Posted July 2, 200420 yr comment_87282 Were the door ding strips factory installed or after market items? In other posts I saw that some were screwed right into the sheet metal and others were glued. My assumption is the glued ones were after market or dealer addons . Is this correct? Link to comment https://www.classiczcars.com/forums/topic/12447-door-ding-strips/ Share on other sites More sharing options...
July 2, 200420 yr comment_87285 I think they were all dealer add-ons. Mine were riveted on. Now they're gone. Link to comment https://www.classiczcars.com/forums/topic/12447-door-ding-strips/#findComment-87285 Share on other sites More sharing options...
July 6, 200420 yr comment_87608 Yep, mine are riveted on too. Link to comment https://www.classiczcars.com/forums/topic/12447-door-ding-strips/#findComment-87608 Share on other sites More sharing options...
July 6, 200420 yr comment_87613 Glued, now gone. Link to comment https://www.classiczcars.com/forums/topic/12447-door-ding-strips/#findComment-87613 Share on other sites More sharing options...
July 6, 200420 yr comment_87618 Riveted, still there.None came from the factory. Link to comment https://www.classiczcars.com/forums/topic/12447-door-ding-strips/#findComment-87618 Share on other sites More sharing options...
July 6, 200420 yr comment_87630 Door ding strips were not a factory part on the S30. Link to comment https://www.classiczcars.com/forums/topic/12447-door-ding-strips/#findComment-87630 Share on other sites More sharing options...
July 7, 200420 yr comment_87753 how would i go about removing the rivets anyway? There is only a ding strip on one side. Looks kinda bad. Link to comment https://www.classiczcars.com/forums/topic/12447-door-ding-strips/#findComment-87753 Share on other sites More sharing options...
July 7, 200420 yr comment_87754 Quote Originally posted by MrMarcDude how would i go about removing the rivets anyway? There is only a ding strip on one side. Looks kinda bad. with a drill bit. You drill out the center of the rivet. Then you'll need to weld the holes in the sheet metal closed. Link to comment https://www.classiczcars.com/forums/topic/12447-door-ding-strips/#findComment-87754 Share on other sites More sharing options...
July 7, 200420 yr comment_87846 sweet, thanks Link to comment https://www.classiczcars.com/forums/topic/12447-door-ding-strips/#findComment-87846 Share on other sites More sharing options...
July 27, 200420 yr comment_89083 I just had my 75 repainted, and removed and replaced the ding strips myself. Easy to do...drill out the old rivets and pop-rivet them back on afta. Be carefull when reattaching strips, so as not to scratch paint Did that on first rivet...when gun popped off ! 26thZ-- my Z looks like your color...what paint code ? Mine is 303 . Emerald Green Link to comment https://www.classiczcars.com/forums/topic/12447-door-ding-strips/#findComment-89083 Share on other sites More sharing options...
July 28, 200420 yr comment_89097 Why did you replace them Link to comment https://www.classiczcars.com/forums/topic/12447-door-ding-strips/#findComment-89097 Share on other sites More sharing options...
July 28, 200420 yr comment_89133 Removed them so the paint job would be better ( less masking,etc )Put them back on cause I don't dislike the looks..and they were a normaldealer accessory in the mid 70's, so to remain "true to the period".Also, they were in great shape...chrome tips and vinyl inserts just like new. Link to comment https://www.classiczcars.com/forums/topic/12447-door-ding-strips/#findComment-89133 Share on other sites More sharing options...
