hi in regards to your fuel pump
in australia the most common thing to do is replace the pump with a vl commodore pump
our commodore came out with the 3.0 ltr nissan motor in it around 1987
this works well out here
thanks
robert
Well in my case I disconnected the return and blew air into the line until it built up sufficent pressure to force the fuel into the pump. I tried not to get any fuel in my mouth but that didnt work too well.
Yes, before you ask, I am quite insane. And proud of it.
It's not the fumes that kill you. Oh... wait a minute..... it is.
Seriously though, make sure the main fuel line and return are not kinked. There is a vent hose as well that you should check.
