So I struggled with it some more this weekend and basically because of how the top baffle plate is cut out to allow for the oil pickup you will not get the pan on without dropping the tranny if the engine is still in the car... Of course if you're doing this on an engine already out of the car and on a stand then there's no problem... (Something I was never told when purchasing it...)
Anyways after a lot of work I did get it on but I thought I should let you all know in case someone else was thinking it would be a quick install...
Oh and it now holds about 7qts when filled to the "H" mark on the dipstick...
-e
https://www.classiczcars.com/forums/topic/12504-cast-oil-pan-fitment-fyi/
