Hi i have just got a set of Noltec Rear control arm bushes (http://www.noltecsuspension.com/product/search.php?selBrand=47&product_vhcid=485), N61613
I assumed that the "rear control arm" is the rear arm that the spring, shocks, brakes etc.. are connected to in the back.. (what the service manual refers to as a suspension arm)
the bushes length wise seem that they should fit, however after removing the rubber bushes and crush tubes, and comparing them to the noltec ones, it seems that there is no way that they will fit the urethane bushes seem to thick to fit (unless you some how have to remove the inner wall of the mount?) and the crush tube has too much play when you insert the bolt.. like 1mm gap, not a perfect fit as is the factory crush tube, enough for it to rattle around.
please tell me i am stupid and looking at the wrong arm (i don't profess to know much, this is my first real hands on project), if so which arm should i be looking at?
Thanks guys!
https://www.classiczcars.com/forums/topic/12565-urathene-rear-bushes/
sorry, no idea what happened there.. any way here was the message:
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys! (sorry about the other post, my computer is playing up)
