Hi all,
I'm planning to add most of the old features back to our site, but, it would be helpful to know what you liked the most. Here's a subset of the features I'll be putting back soon:
1) Image Gallery
2) Random Image Viewer
3) Our "Mascots" on the Main Page
4) Images in the News Area
5) Re-Designed Graphic Theme (old site looked like a MacOS)
6) Upcoming Events in Main Center Block
7) Tabs for Quick Navigation
Etc.... :bunny:
when I go to "www.classiczcars.com" a login screen comes up and doesn't seem to accept my password (it continually comes up after entering my pass). I have to select the "Forums" link to get to the forums. it's like there's no main page. same thing happens if I click "Classic Zcar Club" at the top of the page.
Stephen B: Do you have to scroll way down the page to see the message posts as well?
I've no doubt that it is a resolution item, however, not all of us can afford the 21" plasma monitors. As a result a good old VGA may not be able to give us 1524x768 clearly enough without the use of a 15" magnifying glass.
I've no doubt that there is a setting in the basic vbPortal setup that allows the user to determine his resolution and the program will just adjust the columns accordingly.
Personally, I require the 800x600 res I'm using for work, since that is the main purpose for this computer. So changing to use the site would be a pain.
2¢
Enrique
After adjusting to 1024 x 768, I report that the problem is STILL there. The right hand column overlaps as well as the left.
This may NOT be a resolution issue as much as platform.
SBlake are you using Win95 as I am? That may be the common factor.
Enrique
Enrique:
I just changed my screen resolution to 800 X 600 to see if that caused the problem you reported on my screen, and it DOES NOT. So I guess it isn't related to resolution.
FWIW, I am using Windows XP Home
Vicky is right on with the shout box, it is a convenient way of welcoming new members in front of everyone, whining about kidneystones! LOL , or announcing a visit to the Dayton Wire Wheels factory to arrange for a set of wheels!
Will
Recently Browsing 0
