Posted July 25, 200420 yr comment_88828 Hi I got this switch/knob next to the hazard lights switch and I dont know what's the purpose of it. Its on the right side of the hazards lights switch below the Oil Gauge. I tried pulling it but really nothing happens. Any idea what it is? Link to comment https://www.classiczcars.com/forums/topic/12654-240k-mystery-switch/ Share on other sites More sharing options...
July 25, 200420 yr comment_88838 Does it look stock, or aftermarket? I think the spot there was reserved for fog lights - mine has a little round piece of rubber covering the hole. But perhaps someone put in the switch at a later point in time for something else... Link to comment https://www.classiczcars.com/forums/topic/12654-240k-mystery-switch/#findComment-88838 Share on other sites More sharing options...
July 25, 200420 yr comment_88844 Do you have a instrument dimmer switch next to your choke cable handle?If not, then perhaps the switch you speak of is the dimmer switch, mounted there instead.Or as Alfa suggested, these holes are usually blanked out with a factory rubber/plastic cover and may be an add on switch for something else.Remove the switch from the front, check the colour of the wires, get a torch and check under the dash. Follow the wires and see where it leads you.James Link to comment https://www.classiczcars.com/forums/topic/12654-240k-mystery-switch/#findComment-88844 Share on other sites More sharing options...
July 26, 200420 yr comment_88862 Hey Razor,mine has had an alarm switch placed there. I checked the manuals I have for the C110 .......no wiring to that position from stock, and I can find no optional wiring to that position in the cct wiring diagram, so I'd say it is simply a factory supplied position for add ons such as AlfaDog and James have already suggested. I'd try what James has suggested, trace it out (carefully!) to see what it is/was switching.Cheers, Jim. Link to comment https://www.classiczcars.com/forums/topic/12654-240k-mystery-switch/#findComment-88862 Share on other sites More sharing options...
July 26, 200420 yr comment_88874 The JDM C110 at the local wreckers also has a dial/switch in that position, I'll go check it out at the wreckers in the weekend see if I can't figure out what it is exactly. I also want to steal the twist lockable choke lever from that car so it just gives me another reason to get off my arse. Link to comment https://www.classiczcars.com/forums/topic/12654-240k-mystery-switch/#findComment-88874 Share on other sites More sharing options...
July 26, 200420 yr comment_88875 OOOOoooh, actually, I think I read somewhere that it's the park light switch on some models of C110 which obviously dont have park lights as a twistable option on the column lever. Or I'm talking out my arse, both are potentially viable options. Link to comment https://www.classiczcars.com/forums/topic/12654-240k-mystery-switch/#findComment-88875 Share on other sites More sharing options...
July 26, 200420 yr Author comment_88928 The switch doesnt look like a factory one, just plain looking metal knob switch type.I'll trace the switch later when I finish workbut I do have a parkers switchand I have a dimmer switch next to the choke switchI even have a switch for external electric antennae mounted on my right hand side fender. Link to comment https://www.classiczcars.com/forums/topic/12654-240k-mystery-switch/#findComment-88928 Share on other sites More sharing options...
July 29, 200420 yr Author comment_89279 The mystery switch is my aircon switch Link to comment https://www.classiczcars.com/forums/topic/12654-240k-mystery-switch/#findComment-89279 Share on other sites More sharing options...
August 1, 200420 yr comment_89368 Is your aircon. original or aftermarket? My air works when the temp. and vent position slide controls are pushed to the left, and I select a fan speed...no separate switch. Link to comment https://www.classiczcars.com/forums/topic/12654-240k-mystery-switch/#findComment-89368 Share on other sites More sharing options...
