I have SCCA legal (2002 GCR) Lexan FMR102 windshields (.25") in stock for the 240! I've been working on a source for a while and it has finally come through. $395 plus freight
These are NOT designed to fit inside the old factory rubber or even a replacement gasket. You will have to drill the mounting holes in the Lexan and in your windshield opening flange. (It's not hard to do)
Of course, I have the .125" polycarbonate quarters and rear hatch replacements as well. $25 each for the quarters and $50 for the hatch. I have the hatch replacements that fit inside the gasket or using the same mounting procedure as the windshield, you choose. The sides fit in the gasket using the stock frame.
Come and get 'em! M/C-Visa-Paypal:D
The Lexan replacement windshields weigh in at 12lbs. The original windshield weighs 19.5lbs. GE Structued Products calims some impressive numbers on the impact resistance. See the data sheet for details.
http://www.gestructuredproducts.com/sp1/gesp/industry/product.jsp?gradeCLID=786
Racer-19
