Posted August 5, 200420 yr comment_89966 Howdy,Bought an R180 LSD off the New Zealand equivalent of eBay and when it arrived it looked a bit small. Have since worked out it is a R160. It came with a 3.7 and 3.9 ratio and a Nismo LSD centre.It is in good order but I am not sure if it is much chop for my 240z which has an open 3.9 in it.I was wondering if the LSD centre can still be used in my spare R180 casing or whether I should start again.....Does the R160 bolt in? This is for a street car running mild hp so I am unlikely to break it. I know it is not as strong as a R180 or R200Bugger!!!CheersGlenn Link to comment https://www.classiczcars.com/forums/topic/12766-bugger-r180-lsd-i-bought-is-actually-a-r160-is-it-still-useful/ Share on other sites More sharing options...
August 5, 200420 yr comment_89974 Interesting question Glenn,I too was wondering if the internals to lets say a 3.54 R-180 would fit inside a 4.11 R-180 case or vice-versa? This way you could save on shipping costs by just having the gears sent to you instead of the entire diff assembly. Link to comment https://www.classiczcars.com/forums/topic/12766-bugger-r180-lsd-i-bought-is-actually-a-r160-is-it-still-useful/#findComment-89974 Share on other sites More sharing options...
August 5, 200420 yr comment_89991 Hell, I was thinking about bidding for that. Hard luck. Have you any recourse with EBay and the seller???? Link to comment https://www.classiczcars.com/forums/topic/12766-bugger-r180-lsd-i-bought-is-actually-a-r160-is-it-still-useful/#findComment-89991 Share on other sites More sharing options...
August 5, 200420 yr Author comment_89992 Cheers - he still reckons it is a R180 so I am going to take it a Z club guy to identify properly - the ring gear is 16cm across and the rear cover is the same as a R160....Will see what happens Link to comment https://www.classiczcars.com/forums/topic/12766-bugger-r180-lsd-i-bought-is-actually-a-r160-is-it-still-useful/#findComment-89992 Share on other sites More sharing options...
August 6, 200420 yr comment_90007 Bruce Woolmore (a member here) should also be able to help. He's also a member of the Auckland Z Club.If you know of any other LSD's about, be sure to give me the heads up. Link to comment https://www.classiczcars.com/forums/topic/12766-bugger-r180-lsd-i-bought-is-actually-a-r160-is-it-still-useful/#findComment-90007 Share on other sites More sharing options...
August 6, 200420 yr Author comment_90011 Thanks - I know Bruce well - may give him a call. I will send you a PM - interested to know about another Z out there. My car originally came from ChristchurchCheersGM Link to comment https://www.classiczcars.com/forums/topic/12766-bugger-r180-lsd-i-bought-is-actually-a-r160-is-it-still-useful/#findComment-90011 Share on other sites More sharing options...
August 7, 200420 yr comment_90156 Here's a heads up on another R160 LSD!http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7914777754&rd=1&sspagename=STRK%3AMEWA%3AITI too had the same question and already posted in the HELP! forum. Sorry if I'm saturating, but I was really curious, and I need an affordable LSD bad so I can start drifting!Please let me know if you learn that the R160 is applicable or not, Nustad!The Doctor Link to comment https://www.classiczcars.com/forums/topic/12766-bugger-r180-lsd-i-bought-is-actually-a-r160-is-it-still-useful/#findComment-90156 Share on other sites More sharing options...
August 8, 200420 yr Author comment_90260 Yes it can be used - the one I have has the same output flanges as the 240z but the smaller diff and ring gear generates more heat and if you are drifting then it will be toast - go for the R200 for drifting Link to comment https://www.classiczcars.com/forums/topic/12766-bugger-r180-lsd-i-bought-is-actually-a-r160-is-it-still-useful/#findComment-90260 Share on other sites More sharing options...
August 9, 200420 yr comment_90372 ^ Good! Thanks, Nustad. But I'm going to hold off for now. I need to start researching the RB25/RB26 NA swap and I know I'll need to take into consideration the rear end for that. I doubt the R200 will hold up. Thanks again.The Doctor Link to comment https://www.classiczcars.com/forums/topic/12766-bugger-r180-lsd-i-bought-is-actually-a-r160-is-it-still-useful/#findComment-90372 Share on other sites More sharing options...
August 9, 200420 yr Author comment_90389 I also have a Skyline R32 GTS25 and if you are going to put in an RB engine you may as well put in the Viscous LSD R200 from the R33GTS25T or the GTR diff if you go the big $ route.Have funPersonally I am keen to do a RB30/RB25DE NA hybrid with throttle body injection.....one day Link to comment https://www.classiczcars.com/forums/topic/12766-bugger-r180-lsd-i-bought-is-actually-a-r160-is-it-still-useful/#findComment-90389 Share on other sites More sharing options...
August 10, 200420 yr comment_90537 Well now I'm really tossed up in this. I love the inline six and I too am inclined to an NA motor. Nothing is more attractive to me than the F20C from the Honda S2000, but the RB 2L six in NA form would be my RB pick, and it would help me maintain manufacturer integrity.At least I've narrowed my choices, but stalking around hybridz.org last night only spun me around even more. Thanks for the diff advisement; I was looking for it.The DoctorWith lots to contemplate and many dreams to fulfill. Link to comment https://www.classiczcars.com/forums/topic/12766-bugger-r180-lsd-i-bought-is-actually-a-r160-is-it-still-useful/#findComment-90537 Share on other sites More sharing options...
August 10, 200420 yr Author comment_90625 After talks with the seller I am returning it to him for a refund - nobody wins but best outcome all round.Will sit on my hands for a while and then put in a Skyline 4.11 R200 LSD.....CheersGM Link to comment https://www.classiczcars.com/forums/topic/12766-bugger-r180-lsd-i-bought-is-actually-a-r160-is-it-still-useful/#findComment-90625 Share on other sites More sharing options...
