Posted August 8, 200420 yr comment_90273 Does any one know where other end of this spring is supposed to attach to?There is no mention of it in the Hayes manual, but it does show up in the Victoria British catalog. When I took it off it was wraped around the trunnion bolt, but it didn't seem to be doing anything. Any help would be appreciatedVincehttp://www.classiczcars.com/photopost/showphoto.php?photo=11937 Link to comment https://www.classiczcars.com/forums/topic/12794-handbrake-return-spring/ Share on other sites More sharing options...
August 8, 200420 yr comment_90300 There should be a small tab on the body right in between the brackets that the cable is mounted to. Link to comment https://www.classiczcars.com/forums/topic/12794-handbrake-return-spring/#findComment-90300 Share on other sites More sharing options...
August 9, 200420 yr Author comment_90343 The Spring is hanging from the small hook between the cable brackets. There just doesn't seem to any place on the cable assembly to hook the spring onto. Link to comment https://www.classiczcars.com/forums/topic/12794-handbrake-return-spring/#findComment-90343 Share on other sites More sharing options...
August 9, 200420 yr comment_90347 As 2ManyZs pointed out, there is a little tab on the body. Its a small triangular shape with rounded corners, and its pushed out of the pressing which the Handbrake brackets are attached to. Its so small that you might be missing it............. This pic should help: Link to comment https://www.classiczcars.com/forums/topic/12794-handbrake-return-spring/#findComment-90347 Share on other sites More sharing options...
August 9, 200420 yr Author comment_90357 You can't see from the photo but the spring is hanging from the spring tab. There just doesn't seem to be any where to attach onto the cable. May be if I turn the spring around, the other end has a longer hook on it. That might let me hook onto the trunnion. Link to comment https://www.classiczcars.com/forums/topic/12794-handbrake-return-spring/#findComment-90357 Share on other sites More sharing options...
August 9, 200420 yr comment_90382 Well, if you have one end of the return spring attached to the tab on the body, then - as far as I remember - the other end needs to be attached to the U-shaped hanger ( Nissan call it the "Equaliser" ) that the centre section of the handbrake cable sits in.Can you see a small slot on the Equaliser, right where the clevis pin runs through it? Link to comment https://www.classiczcars.com/forums/topic/12794-handbrake-return-spring/#findComment-90382 Share on other sites More sharing options...
August 11, 200420 yr Author comment_90806 Thanks for the reply HS30-H. There isn't anywhere on the "Equaliser" to attach the spring to that I can tell. Without seeing a picture of one installed I'm only guessing. It might not be the correct spring. I'm just going to leave it for now. Link to comment https://www.classiczcars.com/forums/topic/12794-handbrake-return-spring/#findComment-90806 Share on other sites More sharing options...
August 11, 200420 yr comment_90810 The short end of the spring goes to the tab on the body. The long end of the spring goes in a little hole where the center pin attaches to the equilizer. The hole is small and right next to the pin on the back side. Link to comment https://www.classiczcars.com/forums/topic/12794-handbrake-return-spring/#findComment-90810 Share on other sites More sharing options...
August 11, 200420 yr Author comment_90814 I found this pic in another thread about removing the rear diff.My spring is about four times bigger no wonder I can't hook it up. I'll try to get a new spring.http://www.angelfire.com/hi3/hiper/260Zdiffremoval_oldtranstunnel.html Link to comment https://www.classiczcars.com/forums/topic/12794-handbrake-return-spring/#findComment-90814 Share on other sites More sharing options...
