Hey, does anybody know the offset of OE 240Z wheels? Or what wheel width/offset combinations will fit inside the wheel wells?
Thanks,
Alex
please email me
The only way to go fast is to wipe the name off the tires.
  • 9 months later...
I've run 215/60-15 tires on 15x7 zero offset (4" backspacing) wheels, and had slight rubbing at full lock on one side while backing up. I've also run 225/50-15 and had a miniscule amount of rubbing of the rear. 205/60-15s should fit with no rubbing whatsoever. For stock fenders and springs, 7" zero offset wheels are ideal.
