Posted August 10, 200420 yr comment_90568 Getting ready to have our '78 280Z repainted Nissan code 611 Wine Red Metallic. Does anyone know the Dupont formula or code for this paint?Thanks Link to comment https://www.classiczcars.com/forums/topic/12818-nissan-paint-code-611-dupont-match/ Share on other sites More sharing options...
August 10, 200420 yr comment_90570 Can't the Dupont retailer look it up from the Factory Code? Seems like they should be able to. Their # has to be referenced to the Nissan (or whatever manufacturer) code. Link to comment https://www.classiczcars.com/forums/topic/12818-nissan-paint-code-611-dupont-match/#findComment-90570 Share on other sites More sharing options...
August 10, 200420 yr comment_90576 Quote Can't the Dupont retailer look it up from the Factory Code? Seems like they should be able to. By Bambikiller240 I beleive they will.They do here Link to comment https://www.classiczcars.com/forums/topic/12818-nissan-paint-code-611-dupont-match/#findComment-90576 Share on other sites More sharing options...
August 10, 200420 yr comment_90581 PPG is a better paint in my opinion and they can match any color under the sun. I would think your Dupont rep could do the same, no?Vicky Link to comment https://www.classiczcars.com/forums/topic/12818-nissan-paint-code-611-dupont-match/#findComment-90581 Share on other sites More sharing options...
August 10, 200420 yr comment_90582 Nearly any competant body shop and certainly any body supply shop will be able to look it up on the computer. Of course, they will only be able to tell you the code of the paint manufacturer they use at that shop.I use the computer at the Dodge dealer to look up paint codes for Dupont.If the computer doesn't go back that far in time, their books certainly will. Link to comment https://www.classiczcars.com/forums/topic/12818-nissan-paint-code-611-dupont-match/#findComment-90582 Share on other sites More sharing options...
August 10, 200420 yr Author comment_90583 I am sure the shop can. I was trying to educate myself. I figured someone here might have just gone through this with their car. I assume it is a base coat/clear coat correct?Thanks Link to comment https://www.classiczcars.com/forums/topic/12818-nissan-paint-code-611-dupont-match/#findComment-90583 Share on other sites More sharing options...
August 10, 200420 yr comment_90594 Pretty sure it was a plain old alkyd enamel, they didn't have bc/cc in the late 70's..... Link to comment https://www.classiczcars.com/forums/topic/12818-nissan-paint-code-611-dupont-match/#findComment-90594 Share on other sites More sharing options...
August 10, 200420 yr Author comment_90606 I realize the old paint wasn't BC/CC. Link to comment https://www.classiczcars.com/forums/topic/12818-nissan-paint-code-611-dupont-match/#findComment-90606 Share on other sites More sharing options...
August 10, 200420 yr comment_90607 Zhome.com has paint information and mperdue did this work of art. http://datsunprojects.org/zpaintcodes/ Link to comment https://www.classiczcars.com/forums/topic/12818-nissan-paint-code-611-dupont-match/#findComment-90607 Share on other sites More sharing options...
August 10, 200420 yr comment_90613 the dupont reference code for 611 is 45062 and it is in Centari 600 Clear over base.that is what is in my Dupont book so it should be the same for the USA. Link to comment https://www.classiczcars.com/forums/topic/12818-nissan-paint-code-611-dupont-match/#findComment-90613 Share on other sites More sharing options...
August 10, 200420 yr Author comment_90624 Thanks that what I was looking for. Link to comment https://www.classiczcars.com/forums/topic/12818-nissan-paint-code-611-dupont-match/#findComment-90624 Share on other sites More sharing options...
