Removing the Tacho
Deus Ex
So you've had a dash cap installed and because of that you can't just pull it out from the front?
That IS how you take it out, I've taken mine out several times that way.. But I think due to the shape of the cone you'd have a LOT of trouble getting it out through the back of the dash.. If it can be done at all..
I've also got a dashcap on my 75 and it does hinder removal, although at can be done (on mine anyway) I have to twist the tacho around about a quarter of a circle to remove it as the shrowd isnt perfectly round. It is impossible (afaik) to remove it from the rear of the dash. Best of luck!
Luke
  • Who's Online   2 Members, 0 Anonymous, 783 Guests (See full list)
