Posted April 7, 200223 yr comment_5104 i have a 78 280, and am interested in installing one of the diamond pattern vinyl interiors from the old 240s. i've always liked this pattern, not to mention that the guy who owned my Z before me did a shitty job of attempting to recarpet the interior.should these vinyl patterns fit in my car ? i know that alot of the old 240/260/280 parts are pretty much interchangable. just want to make sure that the vinyl will work before i remove a set from a 240, tear my car apart, and try to install in mine.thanx for the advice. Link to comment https://www.classiczcars.com/forums/topic/1288-240-diamond-vinyl-interior-into-a-78-280z/ Share on other sites More sharing options...
April 7, 200223 yr comment_5106 As far as I know it should work, might be quite a bit of work trying to remove the old vinyl from the 240 though. Most people put the later carpet sets from the 280's in their early cars so I see no reason why the opposite won't work. It definately will make your 280 unique. Good luck. Link to comment https://www.classiczcars.com/forums/topic/1288-240-diamond-vinyl-interior-into-a-78-280z/#findComment-5106 Share on other sites More sharing options...
