Email logins are now active ×
Finally, my Twice Pipes exhuast system is installed.. but problems.. Pics inside
Wow, sounds like you guys had lots of problems... I guess I shouldn't have taken my system for granted! 2.25" header back with a Lukey muffler (I have not heard a better muffler on a Z yet) for $240 Aussie and never had any problems with speed bumps. My suspension was at the stock ride height, though.
I too bought the MSA 6:1 header and premium 2 1/2" pipe system and had problems getting things to fit. Got my independant local muffler guy to do the work and add a glass pack to knock the noise down a little - my neighborhood doesn't have much of a sense of humor.
You should call Sal at MSA (x201 if I remember correctly) and work something out. I would have been happiest if it had all bolted up as advertised, but in the end Sal made it right.
Hi I'm a little late into this thread but I think the Twice pipes are supposed to be over and under not side by side that might be part of your problem..
I also wanted MSA Twice Pipes but read you had to cut a little of the rear valence..I wasnt going to do that to a virgin 71 240 so I had a muffler shop build me a system over and under with glass packs or he called them resonators..said they wouldnt blow out...
Anyway I love them people always seem to know I'm on my way :) ..Guys on bikes look over say nice car nice sound ..around idle i rumble like a motorboat.. get on up about 2700-3500 and who needs a horn...by the way I dont have a radio in the car driving this way about 2yrs( who needs one)..
Good luck Dave
the resonators aren't properly named. They're called EXPANSION CHAMBERS, and are designed to trap the exhaust/sound of certain frequencies to 'resonate' inside and cancel themselves out. there's nothing inside but space for the pulses to bounce. Modern mufflers are designed with suchchambers inside, and so they are bigger in size, but the older/sporty cars use them to decrease backpressure & make more power while keeping the exhaust tube size small.
Well..
the exhuast shop tried to have the pipes go Up and Down... instead of Side by Side... but the Muffler had mounts to bolt onto for it to be upright.... and the tips are angled upward as well.
So if I put the pipes Up and Down, the tips would be facing left or right... and wouldn't look right.
I would try to adjust em myself now.. but the damn exhuast shop welded everything together.
I LOVE the sound... but I don't like how low they sag, and it's side profile.
If it was more tucked in.. it would be PERFECT
alright.. well I went back down and pushed and moved and shoved my way around.
The reason why it was soo close to my tires and it was sitting too low was because the IDIOTS at Midas....
Didn't tighten the bolts all the way.. and the ones they did tighten, they were at horrible angles.
Everything is fixed now... still a bit low.. but no tire rubbing... no vibrating... not as much scraping...
Overall.... I give the sound a 9 out of 10 (very loud, but sometimes annoying)
Install ease ... 5 out of 10 (too much adjustment and bad fit no matter what)
Powergains .... 7 out of 10(felt a good power gain not as much as expected)
NOTE : This is the Twice Pipes on my 280Z ... the install and fit and power will be different for a 240Z without a doubt.. since the setup was designed for a 240Z not a 280z
  • Who's Online   1 Member, 0 Anonymous, 244 Guests (See full list)
