Is there a website that explains all the lingo used in pace notes for rallying? It would be nice to understand what those guys are saying (in english).
I don't speak finnish, french, etc., so I'm not iunterested in that.
thx
https://www.classiczcars.com/forums/topic/12898-rally-navigator-lingo/
hmm...
Well... here are some common rally naivagtor lingo...
Typically it goes like this...
Turns and Speed... on a scale from 1-6. When they say Right 6 for example it means a gentle gradual turn which you can keep heavy throttle throughout the turn. And a 1, would be a very difficult turn, usually a 90* degree turn or more that requires massive braking. So 6 being easy and down towards 1 being the hardest.
Care : Hazardous
Caution : Very Hazardous
Crest : Rise in terrain hides track beyond.
Jump : Rise in terrain that if taken at speed, wil jump the car into the air. Remember once your tires leave the ground, you have zero control of the car.
Long : A long Corner
Very Long : an extended long corner
Turn : a corner at a road junction
Opens : Corner widens on exit
Tightens : Corner becomes tighter on exit
Narrows : Road Narrows
Don't Cut : Do not drive across the apex of the corner
Straight : Hold a straight line through the coming bends
Bends : Ripples in the terrain which could unsettle your suspension.
Professional drivers also mention distance in Meters.. like
3 left, 100, over crest.
This means, slow down for a left turn, in 100 meters, over the crest.
Hope this helps :)
BTW it wouldn't hurt to pick up a great rally game such as...
COlin McRae Rally 04 for only $19.99 for your PC, PS2 or XBOX.....
also this september.. the new Colin McRae 2005 is coming out!
http://www.codemasters.co.uk/colinmcrae2005/about_game.php
  • 6 months later...
Time to revive this thread! I'm a huge fan of WRC and I've been paying carefull attention to co-driver jargin. I find it a lot of fun to take a little windy section of road and make your own pace notes for it. For example, I made some pace notes that leads me into the mountains to my girlfriend's house, hehe.
Here's and example of something I'd do.
Long 5th gear turn to the right which tightens at the exit, 50 meters of straight followed by a 2nd gear hairpin to the left, then 30 meters over a crest, finally a light right turn that opens into a straight.
lg5R-, 50, hp2L, 30oc, es4R+.
How did you make your notes? Did you just keep them in memory while you drive? Probably using a tape recorder and somebody with a good eye and a fast tongue. I'm sure it takes a LONG time to get the notes right; Maybe even several trips over the same route. I'll bet they use a bigger font with one or two items per line, so you can keep your place easier.
Most of all... a thick anti-seasickness armpatch. LOL
not "slippy maybe" but
only "Slippy"
this is in relation to a turn.. for example...
3 Left, Over Crest, Outside, Slippy
Moderate left turn.. over the crest, stay to the outside, caution slippy (slippery surface)
  Quote
The lot of WRC co-drivers are allowed to go over each stage before the rally takes place. They jot the notes down in massive notebooks. If I remember correctly, there's a stage in Germany that required 95 pages of pace notes!
Also, each co-driver has his own code for different rally "moments" so getting a diffinitive guide is kinda difficult. I find it fun to make up your own code, just be creative!
